Old 01-24-2014, 01:57 PM   #3137
fenton
Just a refresher for some of those that may of missed it. Here is Sojhinn with his TQ250 and Open Flash Tablet E85 tune doing a nice little accel run.
[ame="http://www.youtube.com/watch?v=yeCX7uCOUWU"]BRZ FRS Phantom electric supercharger 0 - 60 E85 - YouTube[/ame]
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
Mr. (01-26-2014), Panda Grahams (01-24-2014)
Old 01-24-2014, 01:59 PM   #3138
fenton
And also here is drift office's Dyno run of ThaTruths car tuned with EcuTek.
[ame="http://www.youtube.com/watch?v=Q_ltL_pbHPY"]Drift-Office : Phantom Full Throttle Electric Supercharger BRZ / FRS / GT86 - YouTube[/ame]
The Following 5 Users Say Thank You to fenton For This Useful Post:
normancw (01-25-2014), Panda Grahams (01-24-2014), SKELLINGTON (01-25-2014), VR46 (01-24-2014), zc06_kisstherain (01-26-2014)
Old 01-27-2014, 05:29 PM   #3139
Robftss
Drives: VW
[ame="http://www.youtube.com/watch?v=41L6HoKqEeM"]http://www.youtube.com/watch?v=41L6HoKqEeM[/ame]
Needles flying around! New discharge/charge gauge.
Sorry for the shakiness.
Robftss is offline   Reply With Quote
Old 01-27-2014, 05:33 PM   #3140
Originally Posted by fenton View Post
Oh yes on a proper tune thats not a problem. You have to remember the big difference is this only works at WOT so no drivability is touched during normal accel unlike other FI cars.
You tuned the WOT load cells so that they have the proper AFR and timing. When you aren't WOT it just uses the standard NA load AFR and timing.
This is the reason that the system actually works without a tune as well.
What if you're at high RPM but not WOT? What is the threshold to crossover to open loop?
Old 01-27-2014, 05:34 PM   #3141
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Dude that limiter is bad ass.
Installed Mods:
Old 01-27-2014, 05:44 PM   #3142
fenton
Good question actually. Our tunner was extremely impressed because there was NO delay in ECU adjusting even though the load table changes instantly when the electric motor kicks on.
The unit does take a small amount of time to "spin up" to its max RPM and that was always enough for the ECU to adjust everything as requested.
Also remember that with this unit the boost is very small up top(in comparison) so the transition is very smooth. IF you hit this down low (2000rpm) you go from no boost to about 5psi instantly and it still gets the fuelling right(with tune).
Old 01-27-2014, 05:52 PM   #3143
fenton
For those that where interested here is a 3rd gear log of my car at 3500ft above sea level on a 26(C) degree day running the TQ300.
My tune(TQ300) needs some work.....hoping @shiv@vishnu can help with that!
Had to zip the file.
Actually from the log i can see that it goes from 0psi to 5psi in 600ms!!! lol
Old 01-27-2014, 06:06 PM   #3144
I'm actually asking when the transition actually happens, since driving in open loop without needing the power is pretty easy to do on this car (accidentally), and not good for fuel consumption.
Old 01-27-2014, 06:18 PM   #3145
fenton
Oh okay ya. Sorry I don't know the answer to that. I track all my fillups on fuelly and I didnt really see a change.
Sent from my HTC One using Tapatalk
Old 01-27-2014, 06:28 PM   #3146
What do you normally see MPG wise?
Staying out of open loop is HUGE... it's the difference between guys here who get 20's vs 30's on the highway. You can learn to avoid it, but you can also tune to make an open loop state less likely.
Old 01-27-2014, 06:37 PM   #3147
fenton
Oh im pretty sure im in closed then.
Average consumption is 26.5mpg
Going WOT all the time does increase the consumption however.... that and dyno sessions haha.
Here is my fuelly data..... I took a road trip in June 2013 and installed the TQ250 in August.... the blips up in fuel consumption is usually dyno sessions.
For the Americans
7L/100km = 33mpg
8L/100km = 29mpg
9L/100km = 26mpg
10L/100km = 23mpg
The Following User Says Thank You to fenton For This Useful Post:
Gums (01-27-2014)
Old 01-27-2014, 07:49 PM   #3148
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
The threshold is the throttle switch.
In theory you could drive right to redline without ever engaging the ESC...if you wanted to. As long as you don't push beyond the throttle switch you'll be on the "non-boosted" map. You could easily drive at very high rpm in 3rd or 4th gear without going into boost. You could drive in 6th at 100 mph and not even be close to the engagement point.
I regularly cruise on the highway at 70 mph and get low to mid 30 mpg...if I don't get into boost very often. Even so, I've driven with a heavy foot at 75-80 mph and still got mid-20's.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 2 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (01-28-2014), fenton (01-27-2014)
Old 01-28-2014, 09:58 AM   #3149
qtwre
Drives: White FR-S
I'm pretty sure I've followed every page of this, but something I haven't figured out is, for a kit that isn't yet for sale, how do so many people seem to have it? Maybe it just appears that way.
qtwre is offline   Reply With Quote
The Following User Says Thank You to qtwre For This Useful Post:
86-tundra (01-29-2014)
Old 01-28-2014, 10:11 AM   #3150
Sojhinn
Sojhinn's Avatar
I think there are 6 or 7 of us beta testing the unit .
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
