Old 01-23-2014, 10:47 AM   #3123
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by Gary in NJ View Post
My tune is based a standard NA tune, however when the ECU senses boost it moves to maps that Mike developed specifically for the ESC. So if I were to remove my ESC and ask for full throttle my ESC will continue to provide the correct AFR mixture and timing.
Good info. So driving at sustained wide-open throttle with the ESC still fully installed, but boost disarmed for periods of time should be safe as well.
Old 01-23-2014, 10:49 AM   #3124
fenton
Oh yes on a proper tune thats not a problem. You have to remember the big difference is this only works at WOT so no drivability is touched during normal accel unlike other FI cars.
You tuned the WOT load cells so that they have the proper AFR and timing. When you aren't WOT it just uses the standard NA load AFR and timing.
This is the reason that the system actually works without a tune as well.
fenton is offline   Reply With Quote
Old 01-23-2014, 11:08 AM   #3125
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I've been creeping this thread since I wanna say Octoberish. Are we any closer to a release date?
Old 01-23-2014, 11:09 AM   #3126
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Originally Posted by fenton View Post
Well once you get a tune you are good either way, car works fine in winter with the tune.
What I was trying to say was I would be switching the sc from one vehicle (brz with tune) to another (impreza without tune) in the winter. It sounds like the physical sensor could simply be removed and the boost limit would also be removed, if that ends up being the method to limit the boost.
bee_are_zee is offline   Reply With Quote
Old 01-23-2014, 11:17 AM   #3127
s2d4
s2d4's Avatar
Some questions if I may,
Can I get you to clarify what you meant by WOT load cells?
Does it actually move to the next engine load column at their respective rpm?
I haven't seen any logs yet, are you aware of any?
Old 01-23-2014, 11:56 AM   #3128
fenton
Last i heard from Rob he had the first batch of parts required to launch with the exception of the actual compressor wheels.
These he estimated delivery on Jan 26th. Once he gets the compressor wheels he has to assemble and test everything to ensure they meet his specifications.
Old 01-23-2014, 12:02 PM   #3129
fenton
What i mean is that when you go WOT(with the charger) the actual load to the engine is greater.... lets say this value is between 2 and 3. During these load cells the tune is richened to provide a nice safe AFR and timing for the increased boost.
Now if you were to go WOT without the charger on the load on the engine is less.... lets say 1 to 2.... during load cells 1 - 2 the engine runs as if it were just NA. Try not to think of this as only one number however... instead thing of it as like 1.01 - 1.99.
If the engine see's more load it puts in more fuel(calculated by the MAF).
In this case we inject more fuel when there is more flow and when the charger is not engaged we inject the standard amount of fuel.
I am not a tuner by any means but i have a basic understanding of how the engine calculates required fuel and ignition timing required. Rememember that on the top end we arent boost that much so the tune is very close to what it would be NA anyways....
Somebody like @shiv@vishnu should be able to describe this better than I
Old 01-23-2014, 01:23 PM   #3130
fenton
I have some logs. Would you like to see them?
Sent from my HTC One using Tapatalk
Old 01-23-2014, 03:22 PM   #3131
TM
TM's Avatar
Drives: DGM BRZ 6MT
Nice! Do you have any idea how big the first batch will be?
I'm super excited for the Spring!
TM is offline   Reply With Quote
Old 01-23-2014, 03:49 PM   #3132
fenton
I think i remember a number that Rob said but i dont want to say anything out of line in case things have changed.
I will let Rob comment on that i he chooses to.
Old 01-23-2014, 04:05 PM   #3133
raven1231
Well put me on the preorder list! No but seriously can't wait for this!
Old 01-24-2014, 04:40 AM   #3134
clintavo
BTW, for our car it's a Header, not Headers.
Joined tubes are generally referred to plurally. Perhaps in NJ people put their pant on one leg at a time
clintavo is offline   Reply With Quote
Old 01-24-2014, 10:38 AM   #3135
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
We sell Camaro parts and FRS parts. It's been difficult calling it a header vs headers.
PhastekSport is offline   Reply With Quote
Old 01-24-2014, 10:38 AM   #3136
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Talking
Excitement seems to be building here now that we're within a week of the end of January - what say you @Robftss?
VR46 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
