#3095 | |
Drives: Red GT86 manual (July build)
178whp looks like the gains you might get from the exhaust alone. Are you sure that: 1) That it is coming on boost, and there are no leaks 2) That the tuners have actually loaded the stock map tune provided by AVO, or even at least tuned it themselves? 3) What year and month is your twin? Most people put down 230-250whp on Dynojet with basic Stage 1 AVO kits with a factory AVO tune. The stock ECU map might be compensating for a massive lean-out with you running 5psi as well without stock map. My suggestion is to stop driving, bring it back to shop and make sure it's done right. Do a little research on these forums and contact AVO. Something really doesn't gel about what you're making power-wise and you may be in the running for a broken car. |
#3096 |
Drives: Scion FR-S
They said i was only getting 2 psi. they did a boost leak test and said no leaks. I had the base map from AVO loaded almost a year earlier and the car was running fine. I went to make sure everything was running smooth and also to maybe gain a few hp. I have a Perrin CAI and an exhaust dump. I have a 2013 FRS, not sure the month. I took it to a garage in my home town and the guy said i was making 5psi all day. Not sure if BCP was in a rush or i got screwed. I'm only an internet mechanic some what they were saying didn't make any sense to me.
#3097 |
#3098 |
Drives: Scion FR-S
Why? AIR/FUEL ratios seem to be fine
#3099 |
Or so your MAF would lead you to believe. The Perrin intake is one of the few intakes where MAF scaling needs to be corrected by a fair degree to get a useful readout. Remember that the MAF does not directly measure the mmol of oxygen entering the combustion chamber, it just feeds back a derivative marker in volts, converted to grams of air by a conversion table. More volts, more air - but it is a measure that must be calibrated.
The lack of calibration can also account for the difference in measured boost - 5psi if directly measured off an external boost gauge vs 2psi from the MAF. As such - where are you drawing the A/F ratios from? If it's from the OBD2 it might not reflect the reality of what's in the combustion chamber. Also, the stock AVO map is calibrated to the stock MAF. IIRC it just matches fuel to what the MAF suggests and boom, you have a "stoichiometric" mix according to your gauges. It is for this reason I had to relinquish my Injen intake when I went turbo, and return to the stock intake. You're running boost - you won't miss the perceived increased efficiency of the Perrin intake anyway :-P If you're not running the stock AVO map - make sure that your tuner was aware that you were running the Perrin intake - Perrin have a set of scaling tables for MAF that they would want to take account of. |
#3100 |
Drives: Scion FR-S
i have a A/F sensor in the exhaust. But i also have the Torque Pro app reading it from the OBDII and the numbers are the same.
#3101 |
Drives: 14' Brz
anyone had any experience fitting a different turbo with this setup?
wondering in case mine ever hits the fan. not sure where i would even find one for a reasonable price (one that comes with the kit new) |
#3102 |
The turbo that comes with the kit I'm pretty sure is a Greddy TD05 18G if that helps
#3103 | |
Drives: 2013 Toyota 86 GT
You're quickly going to find that going to a bigger/better turbo hits the limits of the kit's standard intercooler though. It's only designed for mild boost. Then once you change that out you're at the limits of the stock block. |
#3104 |
Drives: GT86 GTS
How is this kit for reliability and is anyone running this kit with BRZ edit?
#3105 | |
Drives: 14' Brz
i installed the kit at 13k and at 53k now and they werent easy miles.
#3106 |
Drives: Raven 2016 FR-S
Hey guys,
What size turbo blanket fits this setup? I found it before, but for some reason, the search isn't finding it at the moment. I can't remember if you should get one for T4 or T6. Thank you in advance. |
#3107 | |
https://www.amazon.com/Design-Engine.../dp/B005AU8GSI |
#3108 | |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
