Old 02-28-2015, 02:24 PM   #3067
zERoTu
Drives: 1st RBv2 10 Series FRS
anyone know if i can run the smooth pulley on the tensioner and the others cogged? one of the cogged pulley bearings seized.
also pmed @KraftWerks about getting it warranted
zERoTu is offline   Reply With Quote
Old 03-01-2015, 04:09 AM   #3068
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
hi
What boost is everyone running with the C30 kit? what is the size of the compressor drive pulley (to see if we might have the wrong pulley)
I'm not enterirely sure but it looks our C30 kit is boosting to 1.35bar?!
We have the C30 kit with toothed pulleys
denso 2.5bar map sensor
sard decat exhaust manifold
stock overpipe
sard catted front pipe
milltek resonated catback
OFT with our custom developped map (in progress)
stationairy our map sensor reads 0.06 kpa so it seems to run just over atmospherical pressure even stationairy, then pulls upto 135 kpa at just 5500rpm where we ran out of fuel, DI fuel is at 100% / 20Mpa and port injection is also at about 96% ??? fuelpump duty is at around 86-90% or is 135 just 0.35bar?
it is very weird we cannot get it rich enouh while everyone else runs at stock fuel system? either way we are running to lean. from about 5000rpm upwards
we have fuelpump and 650cc deatschwerks injectors waiting to go in now, but we worry about 1.35 bar on a stock engine (we just blew the stock headgaskets at 5000rpm) so i want to make sure 100% we have the right pulley or maybe our map sensor reads wrong
we have the following settings for the honda/denso map sensor in our oft:
multiplier: 0.367
offset: -0.045
this is a screenshot of a log we made, look at the fuel data and map reading.
any info on pulley size or max boost please?
ST-A is offline   Reply With Quote
Old 03-01-2015, 04:17 AM   #3069
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I believe im seeing around 0.79bar with the old design 75mm pulley.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
ST-A (03-01-2015)
Old 03-01-2015, 04:30 AM   #3070
ST-A
Master Tuner
this is a log from before we upgraded the map sensor
clearly too lean, wa can't get rich enough, but we only could read 0.4bar on the stock map sensor so we upraded it.
Old 03-01-2015, 08:38 PM   #3071
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Has anyone had the tensioner slider (black piece) freeze up on them? I went to readjust the belt the other day and couldn't move it.
D-VO is offline   Reply With Quote
Old 03-01-2015, 08:40 PM   #3072
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Loosen the nut on the back of the tensioner and it should dislodge with a little nudge.
mit_peid is offline   Reply With Quote
Old 03-02-2015, 01:20 PM   #3073
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
is an oil cooler a must for normal DD with no track use??
DAN_BRZ is offline   Reply With Quote
Old 03-02-2015, 01:24 PM   #3074
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Been running my kit without one for over 10k miles and haven't noticed anything bad so far
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
The Following User Says Thank You to Rulin For This Useful Post:
DAN_BRZ (03-02-2015)
Old 03-02-2015, 01:29 PM   #3075
Freeman
Freeman's Avatar
Nope.
Old 03-02-2015, 01:32 PM   #3076
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
I'm not going to be running one when I do my SC install in a couple weeks. The temps here in Canada are a definitely a bit cooler than the us. I'm sure if you have the money it's a good investment however I'm going to run without one for a bit and just monitor oil temps and see how it goes. My car will be a dd and likely not see the track
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 03-02-2015, 06:33 PM   #3077
vgi
Drives: frs
I don't see why not, 1 smooth pulley is better that 3 (noise wise)
But you could just wait for a bit, KW has really good support and they will take care of you. You might also want to make a video to show that your bearing is screwed and send to them.
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
zERoTu (03-16-2015)
Old 03-02-2015, 08:49 PM   #3078
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
That's the way it should be done all the time anyways.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 03-02-2015, 09:30 PM   #3079
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What nut on the back of the tensioner? Someone have a picture?
post_break is offline   Reply With Quote
Old 03-03-2015, 09:16 AM   #3080
mit_peid
Boosted Noob
mit_peid's Avatar
Kraftwerks Supercharger Owners Thread
Maybe it isn't a nut but it is the actual bolt that goes through the KW idler pulley and threads onto the tensioner. You will have to remove your intake piping to get at it easier.
The Following User Says Thank You to mit_peid For This Useful Post:
D-VO (03-03-2015)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
