Old 10-20-2012, 08:10 PM   #3067
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by jpit View Post
Doesn't John have to give us a thirty day notice before he takes off for four hours?
Now that's funny
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 10-20-2012, 08:21 PM   #3068
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Can anyone post data on the AT tunes. These these threads have gotten big.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline
Old 10-20-2012, 08:41 PM   #3069
tonystewart
Data?
Old 10-20-2012, 08:43 PM   #3070
Visconti
Drives: 05 STi
Originally Posted by tonystewart View Post
John
The newest Automatic Transmission Tune is fantastic!
It pulls so much harder than the previous tune.
The stock intake works perfectly.
The idle is smooth as silk, any throttle input is instantaneous.
Torque hump, other than 1st gear, what torque hump? It's gone.
The laying over at 6200-6300 rpm is nonexistent since returning to stock intake.
Boy did I make a mistake buying an Airaid,
They should rename it Airdoesnotaid above 6200rpm
After flash I always allow 10 minutes of idle, never had an issue with a mushy pedal.
I'm very happy your happy.
Sorry for the wait
Send me a log if you can.
Visconti out !
Visconti is offline
Old 10-20-2012, 08:43 PM   #3071
feldy
feldy's Avatar
I have not been able to find any of the dyno graph data from when he posted it for the at. Or info about launch control for the at. I know he has it in place for the MT tunes. Search here sucks. Searching At tune gets all kinds of bad results. Looking for the feature set of his At tunes mainly.
feldy is offline
Old 10-20-2012, 09:18 PM   #3072
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
So I've been having this issue not sure if it's a setting I messed up:
On Stg 1 pumpgas tune. Just installed v1.07
Everything is normal until the car is being pushed really hard- hitting redline etc
All of a sudden the tach starts reading in reverse. 0RPM is now at 8000
While driving the tach will move towards 0RPM as the engine is reved
If I depress the clutch and take my foot off the gas while moving the tach goes to 8k and the shift light starts to flash
If I stop the car completely the tach will move up to 8k, with the shift light blinking and then beep a few times and reset back to 0RPM
From this point on the tach will again function as normal. Once the car is being pushed hard again I get the same issue, tach reading in reverse, and will not reset back to normal until I do a full stop.
Is there some basic feature that I am unaware of, or is this a glitch?
OjiGeorge is offline
Old 10-20-2012, 09:26 PM   #3073
Visconti
Drives: 05 STi
Please make a video
Visconti is offline
Old 10-20-2012, 10:05 PM   #3074
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
I didnt notice this at all ive been pushing the car all night.
Lee358 is offline
Old 10-20-2012, 11:15 PM   #3075
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
I'll be autocrossing the car tomorrow with the new tune. We'll see how it goes. I'll definitely try to use launch control - though it'll be so cold in the morning the tires will just spin, haha.
Jidonsu is offline
Old 10-21-2012, 12:21 AM   #3076
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Just keep the rpms at about 4000-4300rpm..even in cold weather at those rpm the tires seem to stick pretty well soon...if u launch higher like 5000 the back will actually fishtail, done it few times already and scared the shit out of me lol...
brichard0625 is offline
Old 10-21-2012, 03:07 AM   #3077
DSTL
Drives: 2013 BRZ Limited 6MT
Ugh just lost a longer post. Are we not supposed to be flashing our older e85 etc tunes? Confused. Can't tell what's up. I guess at this point I'll flash and see. Guessing everyone who has had safe tunes for awhile are still safe and will get updates as necessary.
DSTL is offline
Old 10-21-2012, 04:18 AM   #3078
zkubidu
Drives: SWP BRZ
Just got my cable kit today...waiting to receive my file and get her flashed. Somehow that just sounded inappropriate.
zkubidu is offline
Old 10-21-2012, 05:40 AM   #3079
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
I was one of the members who had to send my ECU to Ecutek. The ROM loaded correctly and then the program asked me to turn off the ignition and then back on. That is when the problem started as the instrument panel started blinking and relays were being tripped and the car wouldn't start. By the way, does anyone know if the regular fuel gauge is controlled by the ECU - mine is acting very strange.
Mine is acting very oddly w/ 1.07, as well. The electronic readouts are going bonkers, and the analog gauge is stuck around 75%, even though the pump is shutting off when I try to fill it more.
I flashed back to stock and it didn't seem to make a difference, so I'm a bit concerned. The e-readout seems to be working correctly now, but the analog gauge didn't go back up to full. I didn't have much time to drive it after, though, as my GF was waiting for her food, but I'll go mess around with it more.
Filled out the form and emailed you, John.
Symbiont is offline
Old 10-21-2012, 06:51 AM   #3080
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
I had a similar thing happen with the previous version. The gas went limp and it didn't go back up till it was filled up. Then it stayed at 1/4 higher then it actually was until I got the gas down to where it went funky. Then it actually fixed itself and the gauges are ok. But maybe running it out of gas will help you too.
LeavingNormal is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
