#295 |
Drives: FR-S 6MT
I moved mine back up.. It makes the clutch pedal more firm .. I'm almost back to the stock position and I like it better actually.. Truth be told.. I should have left it alone.. Now that I have more miles on my car.. Everything seems to have fallen in place and shifting has improved on its own.. So the stock height was not so bad after all.. I just needed to be a bit more patient..
#296 |
Drives: BRZ Sport-tech
Everyone should go under their dash and take a look, even if they don't want to perform this mod. I was very unhappy to find that my sensor was HARD against the pedal, meaning that movement was being restricted. This *shouldn't * be a problem, because the clutch pedal should have deadband at either end of its travel range. By deadband, I mean that the pedal is moving without physically moving the clutch. But my sensor was essentially riding the clutch since brand new.
This mod only moves the pedal, it has a small effect on the clutch. Because the pedal bottoms out at the same location, it may not be possible to fully disengage the clutch if you adjust it too low. That said, with the clutch pedal even with the brake, there is at least 1" of pedal travel at the bottom where the clutch is not engaged at all (new clutch). For those that said their pedal feels lighter, it's true. Adjusting the pedal down relieves some of the tension on the pedal return spring. Even without the spring, the pedal should return completely, but it would be ridiculously light. The spring is there only for clutch feel. |
| The Following User Says Thank You to PMPB For This Useful Post: | ProjectD (07-02-2013) |
#297 |
Drives: '04 350Z/ 2013 LR BRZ (LM)
its like I get what your saying....but at the same time its kinda confusing. I understandthe fact that the sensor is "riding the clutch".....but everything was mixed lol
could you post a video or perhaps pics to isolate it? thanks. |
#298 |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
After 3600 miles I finally tried this and it worked wonders for my 1st gear starts. A few notes from my experience.
I removed the pin as mentioned above and turned the "U" Bracket instead of the rod. I also payed a lot of attention to the top and bottom pedal play to make sure that when the pedal is slightly depressed the clutch rod does not move. This was to make sure the switch was not "Riding" the clutch. On the bottom, I made sure all the gear changes did not change the idle RPM with the clutch in sitting still. Finally, I depressed the clutch slightly while driving under throttle to make sure I could feel when the clutch began to disengage so I am confident I have just a little play on the top before the clutch begins to disengage and on the bottom before the clutch begins to engage. The pedal does feel softer but now I can slide my foot from the dead pedal to the clutch instead of having to lift it up. Cheers to the OP! |
| The Following User Says Thank You to ntron1 For This Useful Post: | jcw99 (01-24-2015) |
#299 |
I can't take a picture right now, because I don't have my car. So I made a small paint stick drawing to illustrate.
#300 |
#301 |
Hail Magnet
I don't know if I failed to tighten everything down correctly, but it almost seems like my clutch pedal has come back up to stock height. I'll have to verify this later.
#302 | |
Drives: FT86 GTS
Are there any bad side effects to having it in the 'bad' position? I might need to go back under and fix mine. My back will not be impressed =( |
#303 |
Well, if the sensor is holding down the clutch at all, it could cause the clutch plates to slip and wear out faster. That's why it's 'BAD'.
#304 |
The Comedian
Drives: SWP BRZ Limited
I just got my car and I need to do this. I've been driving stick for years and this clutch catches so high, I hate it. Reminds me of the Evo IX clutch, but much weaker
#305 |
Drives: JRSC'd Asphalt FR-S
I finally got around to doing this, I was already used to the clutch and how it engages, but I did it anyway since I can change it back if I didn't like it, but wow this is so much better! Been missing out!! D:
@JonnyRocket thanks for the video, super helpful! Last edited by Wes; 07-10-2013 at 04:12 PM. |
| The Following User Says Thank You to Wes For This Useful Post: | JonnyRocket (07-10-2013) |
#306 |
Drives: 2013 Subaru BRZ
I did this Mod a couple days ago and it's great! I adjusted mine slightly below the brake pedal.
The only thing that bothers me is that the first 1/4" to 1/2" of depression feels too loose as if the spring is loosened. Can anyone explain to me why that may be the case? Because of this, it feels like my clutch pedal feels... "cheap"? Should I move the pedal to around slightly above brake pedal? *Edit 07-30-2013* Re-adjusted, tightened and didn't feel that weakness anymore. Derp. Last edited by MFPC; 07-30-2013 at 11:38 PM. |
#307 |
Conedancer
Drives: 2013 Subaru BRZ SWP
subscribed..
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#308 | |
Drives: Subaru BRZ Limited
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 11:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 03:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 02:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
