Old 10-30-2013, 07:58 PM   #295
dsgerbc
Drives: BRZ(sold), STI
I might try 18x7 if I find the wheels with ofset <45 for cheap. But only because I have a set of Michelin PSS I'd rather burn than sell used at a half-off.
18x7 moves the heavy part of the wheel further from rotational center, hence increasing the rotational moment of inertia, effectively making the wheel heavier.
So I wouldn't do it if I really wanted to be competitive.
dsgerbc is offline   Reply With Quote
Old 11-03-2013, 11:23 AM   #296
toeout
Question about the RPF-1': Do they go in and out of stock periodically? I don't need a set till spring, but I'm worried that they might be sold out when I need them.
Plan is to get the RPF-1's with 235/40 ZII's.
How do guys handle the TPMS sensors and are the stock lugnuts usable with the RPF-1's?
Thanks.
toeout is offline   Reply With Quote
Old 11-03-2013, 01:38 PM   #297
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Thanks.
The 17x7 5x100 RPF1s do seem to be stocked in less quantities. The 17x8 5x100 seem to have the highest availability, but that obviously wouldn't be legal for RTR/C-Street. Just give Tirerack a call and they could probably give you an idea of how often they plan to get shipments of that size between now and early spring.
I personally wouldn't worry about getting extra TPMS sensors if you're primarily getting these wheels for autocross/tracking. Sure the TPMS light will be on and blink at you every now and then, but it doesn't bother me.
For lug nuts, I definitely would not use the stock lugs on RPF1s; the stock lugs don't have an ideal taper shape/angle for most after market wheels. If I remember correctly, Tirerack will send you open ended lugs for free that work just fine. I personally have used Motegi and Gorilla spline-drive lugs on my RPF1s and they worked great.
jprice130 is offline   Reply With Quote
Old 11-04-2013, 10:06 AM   #298
mla163
Overthinking it
Drives: BRZ in CS
The 17x7 RPF1 is only available at Tire Rack and is not in very high demand. They go in and out of availability. Nobody wants a 17x7 except for us silly stock class autocrossers.
I ordered a set last Fall with an estimated delivery date 4 weeks out. I ended up getting them a few weeks early. So they are out there, you may just need to wait and make a few calls.
mla163 is offline   Reply With Quote
Old 11-04-2013, 10:16 AM   #299
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
spending 800-1000 bucks to save what, 3-4 pounds per corner is harsh-browns
i think i'm just gonna continue to run my oem wheels for next season.
Old 11-04-2013, 12:00 PM   #300
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
It's unsprung weight, but you're right. I'm not sure if that weight savings would matter for us in RTR/C Street.
G_Ride is offline   Reply With Quote
Old 11-08-2013, 10:36 AM   #301
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so i've been following this thread and feel that this is exactly the type of product i've been looking for.
a high quality damper, fully adjustable damper with dataloging capability, to be used with OEM springs.
http://www.ft86club.com/forums/showthread.php?t=44630
however, SCCA rules state that electronically controlled shocks cannot be used... is this a case of interpretation? If you simply remove/disable the parts that would allow you to adjust on the fly (such as removing the controls from the cockpit) then the shock becomes no different than anything else.
anyone have experience in such a matter?
Old 11-08-2013, 11:05 AM   #302
mla163
Overthinking it
Drives: BRZ in CS
That looks too baller and expensive to be legal.
Old 11-08-2013, 11:12 AM   #303
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no different than what i could pick up from Ohlins or MCS, but theirs don't come with data-logging
Old 11-08-2013, 11:51 AM   #304
G_Ride
G_Ride's Avatar
I can see it being legal if you just have manual adjustment. You'd have to completely remove the components that allow them to be electronically adjusted.
Old 11-08-2013, 12:31 PM   #305
qoncept
qoncept's Avatar
Yeah, without digging in to the rulebook (asking for trouble?) the way I remember the rule is "electronic" was an example. The intent of the rule is to prohibit the ability to adjust while driving.
qoncept is offline   Reply With Quote
Old 11-09-2013, 12:30 PM   #306
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
That might work, because I believe you can use multi-adjustable shocks if you disable some of the adjustability functions.
MTCRX is offline   Reply With Quote
Old 11-10-2013, 06:03 AM   #307
mpicher
Autocross Nut
mpicher's Avatar
Drives: Argento 2013 Scion FR-S - MT
And I think there's another problem with disconnecting...
From that thread in one of DougW's responses: "The shock disconnected is full hard."
So this might be something for STX but I don't think this is a CS/RTR suspension option.
mpicher is offline   Reply With Quote
Old 11-13-2013, 11:11 AM   #308
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
our local autocross organizers have Yokohama as a major sponsor.. we all might get really good deals on the AD08r.. but from what i gather this tire doesn't stand up to the price and utility of the new Dunlops or RS3s
thoughts?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
