#295 | |
Drives: It has 4 wheels
Rays do their latest TE37 Saga SL in 18x9.5 5x100 +45 and best of all, in Face 4 ![]() Being a 2nd-gen, it just needs some 6-8mm spacers up front to set it off once you get camber sorted. |
#296 | |
Drives: English, French, Swedish & Japanese
Thanks mate. I assume the spacers wouldn’t be needed up front of running 1.5 or so front camber. |
#297 | |
Drives: '23 BRZ Limited
It's going to take reta-- camber and tiny tires to fit that setup.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#298 | |
I found out the hard way that even lowering the rear by 28mm gets -2.5 rear camber without camber arms. That's a fair bit more than the -1.8 that I wanted and expected. You want to run the same camber up front at the bare minimum. For a very mild street setup with rear camber arms, I'd run -1.5 rear and -2 front. Without camber arms, just run the same up front as your rear camber, never less. Long story short, gen 2 NEEDS spacers up front unless you buy wheels with different offsets. |
#299 | |
Drives: 2022' GR86 Premium 6MT
I'm on 255/35 Squared, no rubbing under full compression in the rear, no cutting required. Stock RLCA, very functional setup.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#300 | |
Thanks mate. I get the point re camber, but keen to run OEM top hats on my coilovers (comfort) so the max adjustment up front get to -1.5 or so. Had this for years (with 2.5 rear) on my 86 with no issue. Sure, a little bit more up front would be great, but for a street car it was fine. Just trying to confirm whether I’d need spacers up front with 1.5 camber. Think it’ll be ok, but ill be able to do some test fitting in a week or so
#301 | |
#302 | |
9.5 ET 45 vs 9 ET 22 is more than a half inch difference to the outside. Technically .669" to the outside.
#303 | |
#304 |
Mebmer
Drives: Sienna, GR86, TourX
#305 |
My apologies for not remembering one particular members exact wheel fitment. But the point stands, not including offset with width makes it hard to judge what will or won't fit.
Please forgive me.
#306 |
Drives: 2022 WRB Limited 6 Speed
Boy has it been a while lol, but at a point where I finally feel complete with the car.
custom clear tails, triple chrome gramlight 57dr, along with full paint matched trd style kit. Full adjustable rear suspension and utilized RUCA/RLCA to bring in the rear track width, currently sitting at around -1.5 rears with -5.5 fronts (drift spec) |
#307 |
Drives: 2022 GR86
Test fitted new wheels for the autocross/ HPDE season:
#308 |
Beefy!
| GR86 Premium MPG | joeDoe | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 40 | 01-31-2022 01:03 PM |
| Why BRZ Over GR86? | Lelandjt | BRZ Second-Gen (2022+) — General Topics | 45 | 12-26-2021 08:41 AM |
| GR86/BRZ Aerodynamics | Jianlun | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 4 | 12-15-2021 10:39 AM |
| GR86 PCD | teppey | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 23 | 07-29-2021 11:12 PM |
| GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 28 | 07-18-2021 03:38 PM |
