Old 03-15-2023, 08:21 PM   #295
bradsm87
Drives: It has 4 wheels
Originally Posted by ACT86 View Post
Perfect setup mate. I’ve been searching far and wide and seems 5x100 18x9 ET45 wheels are pretty rare!
18x9.5 works great with 255/35 too.
Rays do their latest TE37 Saga SL in 18x9.5 5x100 +45 and best of all, in Face 4
Being a 2nd-gen, it just needs some 6-8mm spacers up front to set it off once you get camber sorted.
bradsm87 is offline   Reply With Quote
Old 03-16-2023, 04:15 AM   #296
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Thanks mate. I assume the spacers wouldn’t be needed up front of running 1.5 or so front camber.
ACT86 is offline   Reply With Quote
Old 03-16-2023, 01:18 PM   #297
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by VoltsFRS2013 View Post
Next 12-14 months I'm sure a lot of wheel companies are going to start pumping out 18x9 as 22+ specific fitment honestly. It's a really solid size.
For stance guys sure, my 245/35 Conti ECS just get inside the fenders at -2 camber and reasonable ride height on my 9.5 ET 45 Advans.
It's going to take reta-- camber and tiny tires to fit that setup.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 03-16-2023, 06:27 PM   #298
bradsm87
Friends don't let friends run more rear camber than front. It's the Mcpherson strut front that needs more camber than the multi-link rear that has camber gain as part of its design.
I found out the hard way that even lowering the rear by 28mm gets -2.5 rear camber without camber arms. That's a fair bit more than the -1.8 that I wanted and expected. You want to run the same camber up front at the bare minimum. For a very mild street setup with rear camber arms, I'd run -1.5 rear and -2 front. Without camber arms, just run the same up front as your rear camber, never less.
Long story short, gen 2 NEEDS spacers up front unless you buy wheels with different offsets.
Old 03-16-2023, 10:59 PM   #299
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Are you saying 18x9 is going to take retardo camber and tiny tires? Not the case at all man lol
I'm on 255/35 Squared, no rubbing under full compression in the rear, no cutting required. Stock RLCA, very functional setup.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 03-17-2023, 04:34 AM   #300
ACT86
ACT86's Avatar
Thanks mate. I get the point re camber, but keen to run OEM top hats on my coilovers (comfort) so the max adjustment up front get to -1.5 or so. Had this for years (with 2.5 rear) on my 86 with no issue. Sure, a little bit more up front would be great, but for a street car it was fine. Just trying to confirm whether I’d need spacers up front with 1.5 camber. Think it’ll be ok, but ill be able to do some test fitting in a week or so
Old 03-17-2023, 06:12 AM   #301
bradsm87
1.5 camber up front is very mild but OK. What I’m saying is if you have -1.5 front camber, it is what it is but there is absolutely no point having more than -1.5 rear camber if you have -1.5 front camber. Not only is there no performance benefit because you’re already limited by front-end grip, but anyone that knows sports/performance cars look at the car and see more rear camber than front and just think it’s been lowered improperly and cheaped out on camber adjustment.
Old 03-21-2023, 12:05 PM   #302
OkieSnuffBox
You aren't so dense that you're ignoring the offset.....right? Just the width without offset is meaningless when it comes to close fits.
9.5 ET 45 vs 9 ET 22 is more than a half inch difference to the outside. Technically .669" to the outside.
Old 03-21-2023, 10:28 PM   #303
bradsm87
Go back just one page
Thanks!
Stock RLCA, FactionFab FL Spec V2 Coilovers. - 2.8R, -1.3F
18x9 +45 w/ 255/35. No cutting or rubbing in the rear at full compression, inconsistent rub at full lock (only sometimes when parking)
Old 03-22-2023, 08:30 AM   #304
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
But what if you live to antagonize?
fredzy is offline   Reply With Quote
Old 03-22-2023, 02:07 PM   #305
OkieSnuffBox
My apologies for not remembering one particular members exact wheel fitment. But the point stands, not including offset with width makes it hard to judge what will or won't fit.
Please forgive me.
Old 03-22-2023, 02:33 PM   #306
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Boy has it been a while lol, but at a point where I finally feel complete with the car.
custom clear tails, triple chrome gramlight 57dr, along with full paint matched trd style kit. Full adjustable rear suspension and utilized RUCA/RLCA to bring in the rear track width, currently sitting at around -1.5 rears with -5.5 fronts (drift spec)
suhhh is offline   Reply With Quote
Old 03-24-2023, 09:46 AM   #307
RacingredGR86
RacingredGR86's Avatar
Drives: 2022 GR86
Test fitted new wheels for the autocross/ HPDE season:
RacingredGR86 is offline   Reply With Quote
Old 03-24-2023, 05:11 PM   #308
OkieSnuffBox
Beefy!
GR86 Premium MPG joeDoe GR86 General Topics (2nd Gen 2022+ Toyota 86) 40 01-31-2022 01:03 PM
Why BRZ Over GR86? Lelandjt BRZ Second-Gen (2022+) — General Topics 45 12-26-2021 08:41 AM
GR86/BRZ Aerodynamics Jianlun GR86 General Topics (2nd Gen 2022+ Toyota 86) 4 12-15-2021 10:39 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
