Old 10-16-2019, 04:49 PM   #295
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
James,
Definitely would have been better start a new thread. No one's going to go into this thread to look for tt5 optimization information.
That said, ducting and careful brake management is probably going to be your best strategy. You're braking g's are limited by traction not anything in the brake system itself.
949 Racing is offline   Reply With Quote
The Following User Says Thank You to 949 Racing For This Useful Post:
Jamestl (10-16-2019)
Old 10-16-2019, 04:54 PM   #296
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Originally Posted by Jamestl View Post
My hypothesis was that bigger disks/pads *could* increase my G force under braking, which will translate into lower lap times, but I don't have data to prove or disprove it.
I'll let 949 comment more on this, but this general isn't the case. The technical reason for a big brake kit is to increase the useful mass in order to aid in thermal management. There's many other benefits (like 949 mentioned) like decreasing sprung weight, and decreasing consumable cost with 2 piece rotors etc.
But from a physics standpoint, increasing rotor/pad size with all else being equal doesn't necessarily increase total braking torque.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
Old 10-16-2019, 07:11 PM   #297
strat61caster
strat61caster's Avatar
If you can lock up the tires (engage ABS) with your current brakes then the limit of your braking ability is not the brakes it is the tires.
ineedyourdiddly
Old 10-16-2019, 10:26 PM   #298
R2
Originally Posted by 949 Racing View Post
86 Drive Challenge TT at Sonoma this weekend. Sonny and Ed will be there in Blub. Got the Xida protos on finally. Still refining valving spec but we're close I think. Evaluating the new Nankang AR-1 in 255/40R17 against the R888R if we can get some clean laps and steady temps/sunshine.
If you will be there, Sonny will start giving rides probably 3rd session. First two sessions are solo, go time for the TT and dialing in the setup.
Yes, as mentioned a few times above
That photo shows a good amount of droop in front, comparable to stock I'd say. What ride height would this be adjusted for compared to stock?
R2 is offline   Reply With Quote
Old 10-16-2019, 11:05 PM   #299
949 Racing
949 Racing's Avatar
We have been running about 140mm front pinch weld height with 5mm positive rake on 255/40/17. Pinch weld height changes a bit with taller than OEM tires.
R2 (10-16-2019)
Old 11-26-2019, 03:55 AM   #300
SonnyMod
Drives: 2013 Scion FR-S (949 Racing)
New Chuckwalla CCW 86 N/A Record
Here's the 86 N/A record 1:59.311 Chuckwalla CCW lap set on Sunday morning. Hard to believe a 1:58.9 is possible, but I'm still happy with my driving and confidence the 949 Racing XIDA coilovers gave me on Blub.
Just the way the rear end is so stable that I can throttle steer to change the car's attitude at will on every long double apex corner. Also, the entry speed is just almost too fast, but front end stability under trail braking allows.
[ame]https://www.youtube.com/watch?v=8CzvKfpyS0s[/ame]
SonnyMod is offline   Reply With Quote
The Following 7 Users Say Thank You to SonnyMod For This Useful Post:
Icecreamtruk (11-26-2019), Lincoln Logs (11-26-2019), PulsarBeeerz (11-26-2019), solidONE (12-03-2019), turbofan (11-27-2019), wparsons (01-07-2020), Zer0 (11-27-2019)
Old 12-03-2019, 08:01 PM   #301
949 Racing
949 Racing's Avatar
A few pics from the last event
Old 12-04-2019, 01:36 AM   #302
FRSH86
Any updates on when these might be ready for order/delivery? Thanks.
FRSH86 is offline   Reply With Quote
Old 12-04-2019, 02:45 PM   #303
949 Racing
949 Racing's Avatar
No updates at this time. Working on some minor tweaks to strut flange geometry and end link mounts. Everything else is sorted and ready for production.
solidONE (12-04-2019)
Old 12-04-2019, 03:42 PM   #304
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
The end link mount on the strut could be moved a tiny bit outward to clear the frame rail on cars with high - camber (adjusted using camber plates) and lower ride height settings. Most just deal with it and try to find the lowest profile end link they can find. If that is one of the things you are addressing, you'll probably be the first and only company to do this.
Intent > Content
Old 12-04-2019, 04:59 PM   #305
949 Racing
949 Racing's Avatar
We are often the first.
AngelGT86Racer (12-06-2019)
Old 12-24-2019, 02:50 PM   #306
949 Racing
949 Racing's Avatar
New front aero. In attempt to reduce weight on the nose and increase aerodynamic surface area, we put the OEM front bumper skin back on and grafted an Ikon Motorsport (ebay) urethane lip for a BRZ. It sorta fits but is close enough to be secure. We noticed how flexy it was so we road tested it before we took it to the track. Hung out the window of our minivan at 85mph while we took pics of the lip ob Blub. Sure enough, it was oscillating heavily. So we added a 1/8" sheet of alumalite underneath the lip itself to stiffen it. Only took about an 8" strip to make it solid.
At Buttonwillow 86 Cup event last weekend, Sonny reports that it definitely made a bit more downforce in front than the APR bumper. We were able to crank the ducktail to max angle and achieve excellent aero balance. Combine with a slight change in rake by raising the rear ride height two turns, we got that much sought after neutral balance at both low speed (no aero) and high speed, (aero). Cotton Corners (55-60mph) and Riverside (103mph). Good enough for a new N/A and Mod class record of 1:56.33 on 13CW
Even with the bit of alumalite, this spoiler set up weighs less than the APR bumper. Unfortunately, Sonny had an off and tore the thing off in the next session. $80 on ebay and about $20 worth of alumalite. Gotta love cheap speed. We decided to work with Renderos Racing to make a more refined version in FRP that he can sell. Look for that in the coming months.
The Following 4 Users Say Thank You to 949 Racing For This Useful Post:
Code Monkey (12-24-2019), ka-titties (01-02-2020), phm14 (05-15-2020), turbofan (01-28-2020)
Old 12-24-2019, 03:50 PM   #307
SonnyMod
Short summary of Blub's handling from Buttonwillow on Saturday:
I can use all 200whp and and have the full throttle commitment almost everywhere where it matters, specifically from exit of Cotton Corners to Bus Stop, then Bus Stop to Phil Hill. That is where slow speed and high speed grip/balance is confidence inspiring.
And in the rain on Sunday:
The front suspension/tires are eager to turn in on entry and transitions (Cotton Corners), and rewards you for using slow, smooth brake and steering inputs. I played around with more aggressive (quicker) inputs, and the tires/suspension will let you know when they are sliding/scrubbing, very communicative in the steering wheel (easy to feel).
Rear end of the car rotates nicely on command, but only if the weight transfer under trailbraking was done correctly. Even then, you can correct understeer with on-command oversteer and still not over rotate while compensating. Lastly, if you decided to let the car oversteer (for the fun :P), rotation is slow enough for most to learn on for car control clinics.
The Following 6 Users Say Thank You to SonnyMod For This Useful Post:
Clutch Dog (12-24-2019), Code Monkey (12-24-2019), ka-titties (01-02-2020), phm14 (05-15-2020), radon55 (12-26-2019), turbofan (12-25-2019)
Old 05-04-2020, 02:25 PM   #308
949 Racing
949 Racing's Avatar
Originally Posted by phm14 View Post
This thread is the best reference I've found on suspension set up for the 86/BRZ.
This is an excellent question for a new thread about your project car. Go ahead and start to that new thread and post a link here.
6ul, 949 racing, blub, xida
LED Blub Diffuser? Chimera Cosmetic Modification (Interior/Exterior/Lighting) 5 07-07-2016 01:24 PM
Project Mu Racing 999 brake pads CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-15-2013 04:55 PM
Project Kics R40 racing lug nuts HighbreadEH3 Wheels and Tires 0 09-03-2013 02:49 PM
The Enjuku Racing Project FR-S! Enjuku Racing Announcements, Contests, Giveaways 12 07-19-2012 12:54 PM
