Old 12-31-2020, 01:53 PM   #295
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by x808drifter View Post
The only decent way to get even semi legit numbers for comparing the headers would be to run everything off the same car and dyno and tune for each setup.
Already done by 949 Racing. They said they perform very similar. The JDL had slightly less falloff after 7000rpm than the 350.. Had they had a 250 or 150 overpipe section it may have been different.
PulsarBeeerz is offline   Reply With Quote
Old 12-31-2020, 03:01 PM   #296
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Here's the quote for that, if anyone is wondering. I definitely take 949 at their word, but it would be nice to see actual data on this.
Originally Posted by 949 Racing View Post
Never got a clean graph. Issues with ignition pickup. Even the ones I posted are missing data and spiky. JDL basically same as ACE 350 but didn't fall off as much after 7100, some of that due to the changes we requested to a certain table.
From what I have seen, having many days dynoing our 86, is that weather has a significant effect on readings even when SAE corrected. Same set up would fluctuate about 8whp depending on heat, humidity and barometric pressure. Even wider swings if we turned SAE correction off. Lesson is that direct and precise comparisons can only be made on the same day/dyno/car. Outside of that you are looking more for relative numbers, trends, etc.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 01-02-2021, 02:03 PM   #297
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Just added Crawford BPB to the OEM 2013 manifold. Otherwise same as described earlier in this thread. Last time we dynoed about a year ago, we had coils that were on their way out. Ignition Projects coils now. We plan to dyno again in a few weeks and post results here with all specs. Would be nice to hit 210whp with a cat. Not sure if its possible. We'll see.
949 Racing is offline   Reply With Quote
Old 01-02-2021, 06:47 PM   #298
Goingnowherefast
Definitely looking forward to seeing how the BPB's work with a 4-2-1 long tube setup like JDL's. Have you considered jumping to a 2017 intake manifold yet?
Old 01-02-2021, 07:01 PM   #299
jflogerzi
jflogerzi's Avatar
2017 is not gonna help much plus ppl say it can heat soak faster..
2013 Series 10 FRS #553
Old 01-02-2021, 08:14 PM   #300
PulsarBeeerz
Maybe time to consider sending a TB off to Maxbore.com? A +2mm over bore can deliver a bit more mid range.
Eh, I've ran both. Assuming you have some form of exhaust manifold heat management it isn't an issue... However, the swap isn't worth it unless you extrude hone the IM. Interestingly the MY17 plenum is only half the size of the MY13's.
Old 01-03-2021, 12:26 AM   #301
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I am interested to see what 949 does with the Crawford BPB and Ignition Project coils. I have been lead to believe that neither of these mods should make a measurable difference.
Old 01-03-2021, 12:28 AM   #302
jflogerzi
jflogerzi's Avatar
The BPB is for only pump gas. E85 cars need not apply right?
Old 01-03-2021, 12:36 AM   #303
949 Racing
949 Racing's Avatar
The coils don't add power. They simply don't fail like the OEM ones do. BPB change the flow characteristics of the intake manifold. Fuel is irrelevant. There is a significant amount of data under controlled conditions indicating the BPB do make a difference. And the data all correlate, which further validates the conclusion.
What we are aiming for is peak power at a lower RPM and more total area under the curve. If it loses a bit of power on the top end, that's fine as we don't spend a lot of time there on track anyway. So yeah, we'll see what happens and post the dyno. William at delicious tuning sent us a starting map for the BPB. We'll do some dyno pulls, send the logs back so De can fine tune.
Old 01-03-2021, 12:38 AM   #304
jflogerzi
jflogerzi's Avatar
When the BPBs came out it showed a loss of power when using with e85 in the higher rpm compared to without. Maybe early tuning issue IDK...
Old 01-03-2021, 03:19 AM   #305
PulsarBeeerz
Should be interesting. I've only seen one person make them work with E85 thus far. BUT he did have a dyno chart to proved his claim and yeah the there was literally a mountain of TQ from 5500-6500.
Old 01-03-2021, 11:20 AM   #306
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It should have. The BPB's shift the curve down regardless of fuel. That is why 949 is testing them, trying to get more at lower RPM and willing to sacrifice some on top.
Old 01-03-2021, 11:29 AM   #307
Mike_ZN6
Mike_ZN6's Avatar
I hope we see some feedback on the BPB sooner than later. I am waiting on JDL to build my 4-2-1 now so I should be getting tuned in the next month or 2. If 949 gets the BPB to show real gains I will install a set along with the headers.
Old 01-03-2021, 12:03 PM   #308
jflogerzi
jflogerzi's Avatar
I might be in the same boat. But I am not sure the gains are going to be worth it. Maybe next season in 2022 when my funds are replisnshed
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
