#295 |
Drives: JRSC BRZ SOLD
Already done by 949 Racing. They said they perform very similar. The JDL had slightly less falloff after 7000rpm than the 350.. Had they had a 250 or 150 overpipe section it may have been different.
#296 | ||
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#297 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Just added Crawford BPB to the OEM 2013 manifold. Otherwise same as described earlier in this thread. Last time we dynoed about a year ago, we had coils that were on their way out. Ignition Projects coils now. We plan to dyno again in a few weeks and post results here with all specs. Would be nice to hit 210whp with a cat. Not sure if its possible. We'll see.
#298 | |
#299 | |
2013 Series 10 FRS #553
#300 | |
Eh, I've ran both. Assuming you have some form of exhaust manifold heat management it isn't an issue... However, the swap isn't worth it unless you extrude hone the IM. Interestingly the MY17 plenum is only half the size of the MY13's. |
#301 |
Drives: 2016 Toyota 86
I am interested to see what 949 does with the Crawford BPB and Ignition Project coils. I have been lead to believe that neither of these mods should make a measurable difference.
#302 | |
#303 |
The coils don't add power. They simply don't fail like the OEM ones do. BPB change the flow characteristics of the intake manifold. Fuel is irrelevant. There is a significant amount of data under controlled conditions indicating the BPB do make a difference. And the data all correlate, which further validates the conclusion.
What we are aiming for is peak power at a lower RPM and more total area under the curve. If it loses a bit of power on the top end, that's fine as we don't spend a lot of time there on track anyway. So yeah, we'll see what happens and post the dyno. William at delicious tuning sent us a starting map for the BPB. We'll do some dyno pulls, send the logs back so De can fine tune. |
#304 | |
#305 | |
Should be interesting. I've only seen one person make them work with E85 thus far. BUT he did have a dyno chart to proved his claim and yeah the there was literally a mountain of TQ from 5500-6500. |
#306 |
Drives: Crapcan
It should have. The BPB's shift the curve down regardless of fuel. That is why 949 is testing them, trying to get more at lower RPM and willing to sacrifice some on top.
#307 | |
I hope we see some feedback on the BPB sooner than later. I am waiting on JDL to build my 4-2-1 now so I should be getting tuned in the next month or 2. If 949 gets the BPB to show real gains I will install a set along with the headers. |
#308 | |
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
