#295 |
Drives: C5, GT-86, '24 Colorado TrailBoss
JDM Verus Underbody
First mods today was something I did last year was bought all the JDM underbody panels, Did coroplast plate in between them, also added Verus suspension covers
I never weighed the JDM panels before I installed them but researched their weight online. The Front panels are around 2.25lbs , the rear gas ones 1.5lbs each. So total 7.5 lbs gained. If someone has more accurate on a scale numbers please correct me. Also the Verus suspension covers and hardware comes in at 4.25lbs ![]() Done with aero mods ![]()
| The Following 3 Users Say Thank You to SuperTom For This Useful Post: |
#296 |
TRD Side skirts
Installed Gen 1 TRD side skirts today. I went with them over Gen 2 because I wanted to cut the front part that goes up the fender. Didnt fit exactly how I envisioned but Im still happy with them. Really Series 1 FRS or something like that were the side skirts I should have went with. Only added this weight becuase both side rear panels had damage I wanted to cover.
Added 5lbs ![]() ![]() ![]() also added back in the rear truck matt +2.5 lbs ![]() All the weight gained has me around 2383.25 LBS.
| The Following 4 Users Say Thank You to SuperTom For This Useful Post: | KMA KiCKz (04-21-2025), new2subaru (04-28-2025), Stonehorsw (05-29-2025), StraightOuttaCanadaEh (04-21-2025) |
#297 |
Revo Technica Trunk Brace
Installed the first step of my bracing experiment. This is the Revo Technica Trunk Brace. People may think these are just cheap ebay braces but they developed these for TOM's in Japan and sold at 5 times the price. https://www.86worx.com/toms-rear-body-brace.html
I like that their website lists the weights so you know what your getting into. So 6.5lbs for a combined rear strut brace and rear decklid brace isnt bad. https://www.revotechnica.com/frs_brz_braces.htm ![]() I wasnt sure how the decklid part would mount but it seems there are already factory mount studs for I dunno what from the factory ![]() ![]() I didnt want to deal with cutting up the stock trunk cover so there is 2.5lbs gained back. I used a light piece of coroplast for the base layer and a light trunk mat I had laying around to cut up. ![]() I cant drive yet as Im waiting on some idler pulleys from NST ( I Screwed up and overtorqued one causing it to seize) But hoping this eliminates some of the rear rattles I have from motor and transmission mounts. I am now at 2387.25 lbs |
| The Following 5 Users Say Thank You to SuperTom For This Useful Post: | autoracer86 (05-03-2025), beltax90 (05-04-2025), new2subaru (05-03-2025), NLSP (05-02-2025), StraightOuttaCanadaEh (05-06-2025) |
#298 |
Weight Weenie
Drives: 15 FR-S
Tom, FWIW my experience with NST wasn't good. The pulley's tore my belt to shreds and there was zero customer support. That was a long time ago and they were my first aftermarket purchase.
| The Following User Says Thank You to new2subaru For This Useful Post: | SuperTom (05-04-2025) |
#299 |
Well they advertise 2Days Fast AF shipping. Then they tell me they are waiting on bearings for the pulleys. Ive used them before with no problems but this wait is slowing down my testing.
| The Following User Says Thank You to SuperTom For This Useful Post: | new2subaru (05-06-2025) |
#300 |
Revo Technica Lower Rear Member Brace I [Item# RT20-1088]
We this is my next brace to install the rear suspension brace that ties up the rear control arm area up to the forward subframe. Im sticking with their parts so far because fitment as been good, decent weight, cheap price, and I like how they use 2 mounting points to the frame area most I saw only bolt up to one point.
Weight is in at 3.5 lbs ![]() A few problems the bar on driver side nearly touching exhaust no pic of repair but I did go back and grind some metal off for more clearance ![]() Also the second mounting point that I liked so much ends up interfering with the JDM gas tank covers. My solution for now without cutting anything was just using a long 10mm bolt. The Gas cover gets pushed down a 1/2" away from the body, which affects where my velox suspension covers hang I could go back and either completely chop off that connection to the back bolt or just trim some bar so the plastic fits cover fits flush. ![]() ![]() ![]() Also while in that area today installed the Whiteline Rear inserts KDT925. No post install pics at they were black and hidden. But they did add .75 lbs ![]() I am now at 2391.5lbs. I can only add 8.5 more before I have to find some weight loss elsewhere |
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (06-12-2025), villainous_frx (05-08-2025) |
#301 |
Finally got to drive it with all new pulleys a combination of Raceseng and Nonstoptuning. So heres the $50 paint job with Behr Bonfire Blaze color and redid the engine area as well. Will give it a longer drive to work tomorrow and hopefully can test some of the recent mods.
| The Following 5 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (05-16-2025), KMA KiCKz (05-16-2025), new2subaru (05-16-2025), Raven86Project (06-03-2025), StraightOuttaCanadaEh (05-16-2025) |
#302 |
Small update today got an aliexpress brake booster brace that added about 1/2lb. Also Installed my Raceneng Black crank pulley to replace red one.
SIde note Im trying to order all the parts to convert to the gen 2 aluminum steering knuckles. 2 sites so far have cancelled my order due to backorder no eta. ![]()
#303 |
Not a mod since the braces come from the factory but I took them out before for weight reduction. Now that im leaning towards some structure lightened these and reinstalled with some titanium bolts.
![]() ![]() Also added a cutoff to my rear battery setup. ![]()
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (05-28-2025), villainous_frx (06-12-2025) |
#304 |
Quick mod this morning added the Tom's/Revo Front control arm brace. Why do I like theirs vs the other's Cusco ect. I like that it is bracing an open area, the cusco and others brace laterally across but there already is the factory frame in that area seems redundant.
Added 3lbs vs my Perrin braces. I would pay more for this design if made in aluminum ![]() ![]()
| The Following 2 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (05-29-2025), new2subaru (05-29-2025) |
#305 |
Weight Reduction Day!
Searching for some meat on the bone I realized I still had all the padding behind the dash. I also never removed the wiring and computer for the SRS system. While everything was apart Took out the HVAC I heard there was another AC condenser in there. While taking everything apart realized I still had the dash speakers.
Heres the SRS wiring from the rear of the car and dash area, only snipped off the sensors in the engine area didn't want to splice open those harnesses. The main challenge is these wires are integrated into the main harnesses instead of being separate. Also some of the speaker wiring from the dash and door Got 4lbs from all that ![]() ![]() Next was taking out the dash to get to the HVAC motors. Dont want to get into how I accomplished this but a major PIA to get to that Sound deading and scrape out the tar Got 4.5lbs from that ![]() ![]() ![]() While the HVAC was out took out the second AC condesor out That was 2.75 lbs ![]() ![]() also took out the front speakers good for 1.25 lbs and also did a few "speed holes" on the dash beam. ![]() ![]() Grand total of 12.5 lbs most of it from the front dash area!! This should equal out the weight ive added recently with bracing and the Injen intake. |
| The Following 5 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (05-31-2025), new2subaru (05-31-2025), Stonehorsw (06-08-2025), StraightOuttaCanadaEh (06-01-2025), villainous_frx (06-04-2025) |
#306 |
Seat Restoration
As you will see my NRG carbon bucket have faded and soaked in dirt over the years. Ive been wanting to either take them off and dye or spend the $ for an upholstery shop.
I found A much more cost effective solutions. First I ordered Alcantara replacement covers for NRG Prisma line of seats for $150. I took a gamble as they looked close enough to the design of my carbon buckets. Then I ordered a giant roll of plaid fabric with backing from Etsy for $60. I wrapped that around the existing cushions and used twist pins from underneath to secure. Took a few times to get the yellow lines to line up perfectly. The most time consuming part was DE-stitching out the "Prisma Logo" on the seat top. I kept the outer circle and found Toyota patch the same dimensions. I had to reorder them as Iron-ON patch I accidentally bought velcro thats why they are currently not secured. Im very happy with the results! ![]() ![]()
#307 |
Another round of MODS today!
Ordered this no name brace off ebay it claimed to be aluminum so I took the risk . https://www.ebay.com/itm/176870408128 Was pleasantly surprised to see it was a TTCR-II Brace. It immediately felt very light in my hands and looked great. The new BRZ/GR86 uses bracing in this area our car doesnt have Came out to be 3lbs. ![]() ![]() ![]() ![]() All the bottom plates bolted back on. I had to remove and reinstall 2 of the bottom bolts as the brace and front skid plate shared same location. ![]() Also added in today Carbon Fiber front end links from Racer X. These are a pretty price and was hoping for more weight loss but I suppose you can only go so light for a suspension part and have strength These were 1.7lbs vs my generic adjustable endlinks at 2.8lbs ![]() ![]() ![]() So gained 3lbs from the brace and lost 1lb from the endlinks on the front today. I should be around 2382.5 LBS |
| The Following 6 Users Say Thank You to SuperTom For This Useful Post: | beltax90 (06-05-2025), Lantanafrs2 (06-05-2025), RToyo86 (06-05-2025), Stonehorsw (06-08-2025), StraightOuttaCanadaEh (06-04-2025), villainous_frx (06-05-2025) |
#308 |
Interior
Interior put back together. Trim parts color matched then 2k cleared and of course the newly alcantara covered seats. Also new Alcantara boots and speedo hood (have to redo part of the wrinkle).
-Follow up note: the braces Did what I hope for an eliminated 90% of the bad reverberation I was getting in the car mostly around the passenger door area so a big win. -Eliminating the dash sound deadening did introduce quite a bit of volume into the cabin, mostly clean but louder. I may look for some super lightweight sound deadening options if there is any out there. ![]() ![]()
| mothespaceman: 14' Satin White BRZ Build! | mothespaceman | Member's Car Journals | 25 | 09-19-2014 06:30 PM |
| White BRZ Limited Build Thread | NoFlush | Member's Car Journals | 4 | 05-10-2014 03:04 PM |
| white trd 2013 build | Pcharliep04 | Member's Car Journals | 0 | 04-24-2014 02:25 AM |
| Build-thread White Wasp FR-S by Mit_Peid | mit_peid | Member's Car Journals | 7 | 01-05-2014 08:47 PM |
| White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-02-2013 12:45 AM |
