#3011 | |
Drives: 2018 Subaru BRZ
If you run into any issues with UPlay, as far as your games crashing without even getting to the menu screen. Disable and delete Nahimic Service.
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | Dadhawk (09-02-2021), soundman98 (09-02-2021) |
#3012 |
Not too proud about it, but I was lucky to get it from a distributor instead of a retailer. Runs a bit hot and is loud, but just have to tweak your fan settings/pump settings and set a linear curve with the limit at around 70-80 C
#3013 |
TRACKBREAD
Any PC Gamers Around?
Please run a dedicated psu cable to each connector on that card. It’s a 300 watt card and it can pull ~440 watts over short bursts. Daisychaining the single cable is asking for stability problems when you’re dealing with high transient loads. FYI: PCIe slot: 75W 6-pin: 75W 8-pin: 150W Edit: I think I’m seeing 8+6 pin but I’m not positive. Either way I’d run 2 separate power cables. Full 8 pins not 6+2. Last edited by Yoshoobaroo; 09-02-2021 at 12:13 PM. |
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
#3014 | |
friendly
Drives: 17' 86
Seek comfort in discomfort.
| The Following 2 Users Say Thank You to alphasaur For This Useful Post: | soundman98 (09-02-2021), Yoshoobaroo (09-02-2021) |
#3015 | |
Well fuck. Guess I need a bigger PSU now. I only have one 6+2 PCIE connector.
#3016 |
TRACKBREAD
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | alphasaur (09-03-2021) |
#3017 |
Closes Gigabyte website* Any suggestions on a fully modular PSU?
#3018 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Corsair.
| The Following 3 Users Say Thank You to weederr33 For This Useful Post: |
#3019 |
#3020 |
TRACKBREAD
#3021 |
lol I'm sure you could get away with a 650-850w. I'm only using a 650w and I'm still able to run a ryzen 9 5900x and 3070
| The Following User Says Thank You to weederr33 For This Useful Post: | spcmafia (09-02-2021) |
#3022 | |
As long as it is a fully modular 8-Pin I could stay at 750w-800, correct.
#3023 |
Yup. I like Corsair as they have the small sleeved cables and not the thicc PITA cables.
#3024 | |
I think an RMx 850 should do it.
| The Following User Says Thank You to spcmafia For This Useful Post: | weederr33 (09-02-2021) |
| Tags |
| pc master race, u no have 3080 |
| gamers lounge | Touge_ninja | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 01-21-2014 05:32 PM |
| GT Acadamy Gamers Banned from Britsh GT Pro-Am | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-11-2013 07:37 PM |
