Old 09-02-2021, 11:55 AM   #3011
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Or I could play one of the other games I haven't gotten to yet on my Steam/Epic/GOG/EA/UPlay backlog list.
If you run into any issues with UPlay, as far as your games crashing without even getting to the menu screen. Disable and delete Nahimic Service.
spcmafia is offline   Reply With Quote
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
Dadhawk (09-02-2021), soundman98 (09-02-2021)
Old 09-02-2021, 11:57 AM   #3012
spcmafia
spcmafia's Avatar
Originally Posted by ChazzDiss View Post
Need to save up for that!
Not too proud about it, but I was lucky to get it from a distributor instead of a retailer. Runs a bit hot and is loud, but just have to tweak your fan settings/pump settings and set a linear curve with the limit at around 70-80 C
Old 09-02-2021, 11:59 AM   #3013
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Any PC Gamers Around?
Its here!!
Please run a dedicated psu cable to each connector on that card. It’s a 300 watt card and it can pull ~440 watts over short bursts.
Daisychaining the single cable is asking for stability problems when you’re dealing with high transient loads.
FYI:
PCIe slot: 75W
6-pin: 75W
8-pin: 150W
Edit: I think I’m seeing 8+6 pin but I’m not positive. Either way I’d run 2 separate power cables. Full 8 pins not 6+2.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
alphasaur (09-02-2021), brewloc (09-06-2021), soundman98 (09-02-2021)
Old 09-02-2021, 12:40 PM   #3014
alphasaur
friendly
Drives: 17' 86
FYI:
PCIe slot: 75W
6-pin: 75W
8-pin: 150W
Someone on reddit just posted a pic of a melted cable from daisy chaining on a 3080. Oops.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
soundman98 (09-02-2021), Yoshoobaroo (09-02-2021)
Old 09-02-2021, 01:23 PM   #3015
spcmafia
spcmafia's Avatar
FYI:
PCIe slot: 75W
6-pin: 75W
8-pin: 150W
Well fuck. Guess I need a bigger PSU now. I only have one 6+2 PCIE connector.
Old 09-02-2021, 01:24 PM   #3016
Yoshoobaroo
TRACKBREAD
Don’t get a gigabyte one if you do upgrade.
Honestly - a dedicated 8 pin and a separate 6+2 is probably fine. What is the power rating of your PSU?
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
alphasaur (09-03-2021)
Old 09-02-2021, 01:25 PM   #3017
spcmafia
spcmafia's Avatar
Don’t get a gigabyte one.
Closes Gigabyte website*
Any suggestions on a fully modular PSU?
Old 09-02-2021, 01:28 PM   #3018
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Corsair.
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
soundman98 (09-02-2021), x808drifter (09-02-2021), Yoshoobaroo (09-02-2021)
Old 09-02-2021, 01:28 PM   #3019
spcmafia
spcmafia's Avatar
Originally Posted by weederr33 View Post
Corsair.
RMx Series RM1000x 80 PLUS Gold?
Old 09-02-2021, 01:30 PM   #3020
Yoshoobaroo
TRACKBREAD
My phanteks Amp has been rock solid.
Can’t go wrong with seasonic either. Definitely go 750W or higher
Old 09-02-2021, 02:00 PM   #3021
weederr33
weederr33's Avatar
lol I'm sure you could get away with a 650-850w. I'm only using a 650w and I'm still able to run a ryzen 9 5900x and 3070
The Following User Says Thank You to weederr33 For This Useful Post:
spcmafia (09-02-2021)
Old 09-02-2021, 02:08 PM   #3022
spcmafia
spcmafia's Avatar
As long as it is a fully modular 8-Pin I could stay at 750w-800, correct.
Old 09-02-2021, 02:18 PM   #3023
weederr33
weederr33's Avatar
Yup. I like Corsair as they have the small sleeved cables and not the thicc PITA cables.
Old 09-02-2021, 02:28 PM   #3024
spcmafia
spcmafia's Avatar
I think an RMx 850 should do it.
The Following User Says Thank You to spcmafia For This Useful Post:
weederr33 (09-02-2021)
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
