Old 02-14-2015, 05:55 PM   #2983
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
About to try my heatgun...wish me luck
nlowell is offline   Reply With Quote
Old 02-14-2015, 06:50 PM   #2984
vgi
Drives: frs
Originally Posted by nlowell View Post
Has anyone removed their system to install new pulleys? Any tips on removing the red lock-tite bolts. I'm worried about stripping the heads. I'm also hoping I can do it without disconnecting the supercharger oil lines as I don't really want to bleed the system again or lose unicorn juice. Thoughts?
just unbolt the plate, lean forward and you're good. also you don't need to take off the crank pulley.
vgi is offline   Reply With Quote
Old 02-14-2015, 07:35 PM   #2985
nlowell
nlowell's Avatar
Intake inlet was a B to get off while wiggling the assembly out but I got it. The supercharger pulley was no problem with heat but the second bolt on the crank pulley turned and stripped as feared. Luckily a T30 torx bit provided enough bite to break them all free. I think I'm going to use the new KW pulley wrench to install a new crank pulley bolt while I'm at it. I had a little wobble and I'm going to see if that fixes it.
Old 02-14-2015, 07:54 PM   #2986
raytrix
Drives: Series 10 FR-S
@KraftWerks this pinch looks horrific. I'm thinking of removing the kit now because this bothers me a lot. There should be no reason for any product to have this kind of fitment from the get go. I have a Series 10 car that has the factory HID headlights, the same found in Monogram and all the GT86 found around the world. If there isn't a solution to this, then I guess I have no choice but to get rid of this kit. This is the C38 kit with the 2.5" hose. The headlights on the Monogram/Series 10 has extended section behind the headlight that interferes with the hose that you guys designed to pass behind the driver headlight.
I have fear that when the system is under pressure, the hose will expand and vibrate during operation and possibly start to rub into pieces.
raytrix is offline   Reply With Quote
Old 02-14-2015, 08:06 PM   #2987
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Their R&D car was a BRZ if I remember right. Makes sense that thered be clearance issues with a type of headlight that wasnt available to them to test on.
Anyways best of luck.
Freeman is offline   Reply With Quote
Old 02-14-2015, 08:07 PM   #2988
Freeman
Freeman's Avatar
Just an update: Zero issues with the supercharger kit after 7k miles. Thanks for great kit KW!
Old 02-14-2015, 09:20 PM   #2989
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Have you tried swaping the hose around? I run a open bypass valve, so I swap the hose around, it seems to fit better on the BRZ and on my car.. Also the 10series I just installed.. No issues when I just swap the hose 180*
Gixxersixxerman is offline   Reply With Quote
Old 02-14-2015, 09:22 PM   #2990
raytrix
BRZ doesn't have the LED module built in the headlight design like the GT86 headlights. At the time of KW development, only the Series 10 had the GT86 headlights. Now you can get them on Monogram. This issue was overlooked during development because there wasn't a test dummy to fit this on a GT86 headlight equipped car.
Old 02-15-2015, 12:35 AM   #2991
SPCorBUST
SPCorBUST's Avatar
Try the rotated hose suggestion. It's a tight fit in the BRZ regardless of the smaller C30 coupler or the larger C38 coupler, they both rub to an extent, but the latter is worse.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-15-2015, 08:45 AM   #2992
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I heard someone hit nearly 375hp on e85 with the STOCK pulley c38...
Xero-Limit is offline   Reply With Quote
Old 02-15-2015, 11:39 AM   #2993
raytrix
We already rotated it 3 times to make sure both ends were attempted. The same results was yield at the headlight area. Believe me, the GT86 headlights are way bigger than the BRZ because of the LED module that sits behind the headlight. It's molded into the headlight housing so it's not a piece that can removed. If we dremel that corner then the headlights will not be sealed anymore. BTW no kit should be designed to "rub to an extent" during operations. If this hose was a point of contact in the design, I would of designed a solid pipe in it's place so it wouldn't expand under boost and hit the headlights.
Old 02-15-2015, 01:27 PM   #2994
SPCorBUST
SPCorBUST's Avatar
You heard right...
Old 02-15-2015, 01:58 PM   #2995
SPCorBUST
SPCorBUST's Avatar
I definitely get your point. Haven't heard of anyone in your specific situation in this thread, but haven't heard of anyone with a hole rubbed into their coupler either. It's great that you pointed it out though, it's certainly a point for potential owners to consider.
Old 02-15-2015, 04:04 PM   #2996
raytrix
Page 82 of this thread D-VO had a similar issue but his headlights were not GT86.
http://www.ft86club.com/forums/showt...ts#post1841644
Indeed this issue only will affect probably 10% of the FRS owners which would not be enough to warren a fix since you know how many Monogram, Series 10, and people with JDM GT86 headlight conversions on their base FRS guys want to put a KW supercharger for their car. Certainly I haven't seen anyone specifically wrote about it publicly till now I'm guessing. Does that make me the first test dummy for this specific combination?
You do have some good points about no one have rubbed a hole out on the silicone hose yet for the charge pipe section. But man I'm so anal on this and knowing the fact that I'll be driving the car with that piece "Pinched" rather than just lightly sitting on the headlight just kills me. That will never leave my mind. Would you want to drive around with a turbo kit or a supercharger kit with a built in pinch design in the routing?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
