Old 02-09-2015, 08:06 PM   #2955
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by zoth View Post
Quote from CJ about being able to drive the car without the SC belt.
"Yeah, just stay below 4000 or so to be safe."
Regards,
CJ Weidl
Yeah, keep the car in the RPM window beneath where it was seeing significant boost figures will allow it to drive.
You'll obviously not want to be WOT'ing the car up to that 4K mark either but the car should be safe to drive moderately until the parts arrive, which should be within the next couple days.
KraftWerks is offline   Reply With Quote
The Following User Says Thank You to KraftWerks For This Useful Post:
zoth (02-09-2015)
Old 02-10-2015, 08:26 AM   #2956
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I have had twice now where my car would not boost past 4500rpm in cold weather (-10 Celcius and colder). Its like the car just hits a wall. Is it possible the toroids in the blower are not getting warm enough, because both times it was after extended 100+km/h cruising down the highway?
Works fine in warmer weather and also when I let the car idle for about 20 minutes at ice racing on a warm engine.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 02-10-2015, 08:48 AM   #2957
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Who's your tuner?
post_break is offline   Reply With Quote
Old 02-10-2015, 09:31 AM   #2958
BRZZZZZZZZZZ
Car Nut
Originally Posted by post_break View Post
Who's your tuner?
Airboy. I don't think its a tune problem though, its like the car just hits a wall but the parameters all look good.
Old 02-10-2015, 09:34 AM   #2959
BRZZZZZZZZZZ
Car Nut
Also I don't even have to drive this car in winter and don't really anyway, so it's not a big issue, I am just curious.
Old 02-10-2015, 09:48 AM   #2960
post_break
post_break's Avatar
There was a bug in ecutek related to cold weather. Causing this exact issue.
Old 02-10-2015, 10:05 AM   #2961
BRZZZZZZZZZZ
Car Nut
Is there a fix for it or solution? Any more info?
Old 02-10-2015, 10:20 AM   #2962
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
I was under the impression that was more of an issue with delicious tunes... Not that his tunes are bad. Just in the way they are tuned. Speed density vs maf... Something like that
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 02-10-2015, 01:17 PM   #2963
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
There was a physical problem within EcuTek software in which IAT temps had a lower ceiling and could not read below a certain temp, even though in many areas temperatures were getting far colder. This caused startups to be almost impossible. The problem was there all along in the software, it just hadn't presented itself until the right season came along. EcuTek has since solved the issue and all of our tunes have been updated to resolve any cold starting problems.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Triumphrider (02-10-2015)
Old 02-10-2015, 01:25 PM   #2964
BRZZZZZZZZZZ
Car Nut
Sincerely,
Zach
How long ago was that an issue? My car was tuned locally in early December.
Old 02-10-2015, 01:29 PM   #2965
DeliciousTuning
Because the rotrex works on a traction drive system, it has a very specific minimum operating temperature. Under that operating temperature, the blower will have a very hard time boosting and will often feel as though it is "hitting a wall". An easy solution is to use something similar to an engine block heater to keep the blower warmed up for when you start up in the mornings so that it is already in operating temperature when you're ready to go.
Sincerely,
Zach
Old 02-10-2015, 01:29 PM   #2966
DeliciousTuning
EcuTek recently revised the software within the last month.
Sincerely,
Zach
Old 02-10-2015, 01:33 PM   #2967
BRZZZZZZZZZZ
Car Nut
Sincerely,
Zach
It's not a starting issue, its a cruise speed with no boost on the highway problem. The car lives in a heated garage, but the problem has happened when I see intake air temps around -5 Celcius and colder as I cruise down the highway, the car isnt seeing any boost for sometimes as long as 100km or more.
I will be careful not to drive it in colder weather anymore I suppose.
Old 02-10-2015, 01:41 PM   #2968
DeliciousTuning
In that case I'd definitely recommend contacting your tuner to get the map updated. You shouldn't have to compromise by not driving it in cold weather, just get the map where it should be.
Sincerely,
Zach
zoth (02-10-2015)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
