#2955 |
I got this today:
![]() For more pics and a quick video of some whining check here: http://www.ft86club.com/forums/showt...89#post1486889
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following 3 Users Say Thank You to swift996 For This Useful Post: |
#2956 | |
Drives: 2013 SWP BRZ
If you have the charger installed already you have to remove the back elbow to get the stock fittings off, and replace them (if you see fit). |
#2957 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
There was one more kit after yours and that one sold quick. No more upgrade kits in the US for at least a few weeks after this one!
| The Following User Says Thank You to Xero-Limit For This Useful Post: | swift996 (01-28-2014) |
#2958 | |
Drives: 2013 BRZ limited SWP
Sent from my DROID RAZR using Tapatalk |
#2959 |
WUB WUB
Drives: 2013 Firestorm
okay, so y'all know i'm a big proponent of this supercharger, i really do love it.
BUT! it makes the car almost undrivable in the snow! normally i could creep in 2nd gear from a stop and be fine, but having so much torque immediately makes it spin way too much. i ended up having to ride my wheel along a curb just to get unstuck, and nearly spun twice.
#2960 | |
blowhard
Drives: frs, project forester
I'm on good snow tires and even na is a bit loose in the ass during a storm. Last edited by utekineir; 01-29-2014 at 12:30 AM. |
#2961 |
WUB WUB
stockers still. i'm doing gauges, then axles before i go to wider/stickier tires.
#2962 | |
blowhard
I wouldn't drive this car stock in snow with the oem tires let alone with twin screw, would much rather buy a winter capable set than pay an insurance deductible/premium hike. Sucks for you guys that maybe get one touch of snow a year though. |
| The Following User Says Thank You to utekineir For This Useful Post: | Calum (01-29-2014) |
#2963 |
WUB WUB
yeah, this is probably going to be the only 2 days we get snow this year.
it's okay though, i've borrowed my parents MDX, so i can drive atleast.
#2964 |
Drives: Raven FR-S
I've got a weird hum coming from my throttle body with the ignition switched on......this normal? [ame]http://youtu.be/qq7PvCYv9JI[/ame]
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#2965 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
very normal, many of us have the TB servos humming as you call it in SA.
I paniced and went to Toyota, confirmed no problem. They also said you will get a CEL if the TB is not working. |
#2966 |
Drives: Raven FR-S
Also how long did it take to bleed all of the air out of the system? I swear I've used about 3/4 of my gallon of coolant throughout the day.
#2967 |
Road Warrior
i was going to mention when i heard your water pump for the IC that it sound like its not flowing properly.
after taking off 4 times, this is what i found best. turn car ignition on, fill bottle with water continuously as it pumps in, you hear the pump running like your is. pump the pipe entering the pump continuously you hear bubbles run. pump the pipe going into the front of the charger many many times. you will start seeing when system is full the level in the coolant bottle will rise up and down as you pump the pipe. i aslo gave a blow into the collant bottle to push some pressure into the system. you will hear the pump suddenly running very quiet and smooth when system is full. i found taking the car for a 50km drive slow, had to top up maybe 100ml, from then full no issue. if you still find running low top up few more time. if you go down to low mark after around 4 to 5 top ups, start looking for a leak. |
#2968 |
Drives: Raven FR-S
Innovate Supercharger Owners Topic
I've religiously looked/felt for leaks all day long. I'll test more tomorrow. It seems as though heat cycling (run the car until normal operating temps while driving around, then park it and let it cool) bleeds a good bit of air from the system as well.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
