Old 01-28-2014, 04:48 PM   #2955
swift996
swift996's Avatar
I got this today:
For more pics and a quick video of some whining check here:
http://www.ft86club.com/forums/showt...89#post1486889
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 3 Users Say Thank You to swift996 For This Useful Post:
Alabang 86 (01-30-2014), normancw (01-28-2014), RyanITV (01-29-2014)
Old 01-28-2014, 05:01 PM   #2956
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by olorin View Post
When you swap out the plastic fittings on the back for the brass ones do they just screw into the hole where the plastic ones are? Or do you have to take the SC off the manifold?
If you have the charger installed already you have to remove the back elbow to get the stock fittings off, and replace them (if you see fit).
xxscaxx is offline   Reply With Quote
Old 01-28-2014, 07:29 PM   #2957
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
There was one more kit after yours and that one sold quick. No more upgrade kits in the US for at least a few weeks after this one!
Originally Posted by swift996 View Post
I got this today:
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
swift996 (01-28-2014)
Old 01-28-2014, 07:41 PM   #2958
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Damn that sucks. I ordered my intercooler from Innovate last Monday and they said it should only be 2 weeks.
Sent from my DROID RAZR using Tapatalk
Area86 is offline   Reply With Quote
Old 01-28-2014, 10:32 PM   #2959
wrxgoose
WUB WUB
Drives: 2013 Firestorm
okay, so y'all know i'm a big proponent of this supercharger, i really do love it.
BUT!
it makes the car almost undrivable in the snow! normally i could creep in 2nd gear from a stop and be fine, but having so much torque immediately makes it spin way too much. i ended up having to ride my wheel along a curb just to get unstuck, and nearly spun twice.
wrxgoose is offline   Reply With Quote
Old 01-28-2014, 11:06 PM   #2960
utekineir
blowhard
Drives: frs, project forester
BUT!
What sort of tires? Guessing in nc not too many people run dedicated snow tires.
I'm on good snow tires and even na is a bit loose in the ass during a storm.
utekineir is offline   Reply With Quote
Old 01-28-2014, 11:14 PM   #2961
wrxgoose
WUB WUB
Originally Posted by utekineir View Post
What sort of tires? Guessing in no not too many people run dedicated snow tires.
stockers still. i'm doing gauges, then axles before i go to wider/stickier tires.
Old 01-28-2014, 11:34 PM   #2962
utekineir
blowhard
Tires,tires,tires sir.
I wouldn't drive this car stock in snow with the oem tires let alone with twin screw, would much rather buy a winter capable set than pay an insurance deductible/premium hike. Sucks for you guys that maybe get one touch of snow a year though.
The Following User Says Thank You to utekineir For This Useful Post:
Calum (01-29-2014)
Old 01-28-2014, 11:45 PM   #2963
wrxgoose
WUB WUB
yeah, this is probably going to be the only 2 days we get snow this year. it's okay though, i've borrowed my parents MDX, so i can drive atleast.
Old 01-29-2014, 02:03 AM   #2964
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I've got a weird hum coming from my throttle body with the ignition switched on......this normal? [ame]http://youtu.be/qq7PvCYv9JI[/ame]
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-29-2014, 02:42 AM   #2965
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
very normal, many of us have the TB servos humming as you call it in SA.
I paniced and went to Toyota, confirmed no problem. They also said you will get a CEL if the TB is not working.
Ryan86 is offline   Reply With Quote
Old 01-29-2014, 02:44 AM   #2966
CK_Bladesmith
Drives: Raven FR-S
Also how long did it take to bleed all of the air out of the system? I swear I've used about 3/4 of my gallon of coolant throughout the day.
Old 01-29-2014, 02:59 AM   #2967
Ryan86
Road Warrior
Ryan86's Avatar
i was going to mention when i heard your water pump for the IC that it sound like its not flowing properly.
after taking off 4 times, this is what i found best.
turn car ignition on, fill bottle with water continuously as it pumps in, you hear the pump running like your is.
pump the pipe entering the pump continuously you hear bubbles run.
pump the pipe going into the front of the charger many many times.
you will start seeing when system is full the level in the coolant bottle will rise up and down as you pump the pipe.
i aslo gave a blow into the collant bottle to push some pressure into the system.
you will hear the pump suddenly running very quiet and smooth when system is full.
i found taking the car for a 50km drive slow, had to top up maybe 100ml, from then full no issue.
if you still find running low top up few more time.
if you go down to low mark after around 4 to 5 top ups, start looking for a leak.
Old 01-29-2014, 03:03 AM   #2968
CK_Bladesmith
Drives: Raven FR-S
Innovate Supercharger Owners Topic
I've religiously looked/felt for leaks all day long. I'll test more tomorrow. It seems as though heat cycling (run the car until normal operating temps while driving around, then park it and let it cool) bleeds a good bit of air from the system as well.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
