#2955 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | LostSalad (09-10-2015) |
#2956 |
Drives: Frs
I have tried to search, but I've been unsuccessful. I am going to auto club ROVAL on Saturday and just got some 215/45/17 rivals on stock wheels. The rest of the car is 100% stock (minus the W5 pads). Any suggestions for starting cold tire pressure. I'm bringing chalk so I can adjust, but I really have no idea where to start. 30 psi? 32 psi? 28 psi? Thanks
#2957 | |
#2958 |
Drives: Frs
#2959 |
Drives: Frs
Thanks again CSG Mike! Had an awesome day at autoclub speedway. The new tires and W5 pads were amazing. I've never felt more confident in my car or my driving. As always, thanks to counter space garage and mike for all the help and awesome service getting me the right stuff for the track. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Jeffsu350 For This Useful Post: | CSG Mike (09-20-2015) |
#2960 | |
Drives: Toyota GT86 SWP
I had my car aligned. I've suggested the mechanic to maximize the front camber, and set 0 toe front, and a little toe in back (0.05° - 0.1° each tire). I forgot to tell the shop to measure the stock setup. They have first installed the camber bolts and than measured the setup, therefore I don't know the real values before alignment. However, after camber bolts installation, the values where: about -0.1° front toe total (toe out), about +0.1° back toe total, front camber like -0.1° each tire, rear camber -0.8° left and -1.3° right (I've noticed this strange pattern - right rear tire with more camber than left rear - on most values read on this forum). After the alignment I have the requested values: front camber is now -1.4° on each tire, front toe is perfect 0, rear toe is +0.07° on each tire. My issue is: now the front of my car feels much lighter then before. The steering wheel is a lot lighter, and also it feels like the first inch of steering wheel movement is less sensible. I have to say that my tires are over-inflated, I inflated my AD08R (215/45 R17) at 2.7 bar at the beginning of the summer season (for street fuel economy, and also because the weight of the steering wheel increased a lot from the winter tires to the AD08R), however the pressure has not been changed with the alignment, and before the alignment the weight of the front and the steering wheel was very good. Is it due to the change in camber, or maybe the cause is the change in front toe? What can I do, considering I've not the correct values of the toe before the alignment? |
#2961 | |
A good alignment shop will always set your tire pressures before doing any other work. |
#2962 |
Drives: Stock FR-S
How long can the stock car be continuously pushed near the limit with respect to the engine and cooling? Maybe for around half an hour at 200 kilometres per hour (over 120 miles per hour)?
Brakes and tires would not a part of the equation in this case. |
#2963 |
In what gear? RPMs are what matter for heat so if you're doing that speed in 6th it will be better than in 5th. I think that 200 is reachable in 5th.
| The Following User Says Thank You to jvincent For This Useful Post: | RandomDeception (10-01-2015) |
#2964 |
Drives: 2023 BRZ
I have to think the car is capable of doing 120 mph indefinitely without cooling issues. I don't know this for sure, but I'd be surprised if engineers didn't design and test the car to do this. 120 for a modern sports car isn't all that fast. I'm looking forward to what other more experienced people have to say about it, though. It is an interesting question.
| The Following User Says Thank You to Pat For This Useful Post: | RandomDeception (10-01-2015) |
#2965 | |
With an oil cooler? Forever as far as engine and oil temps go. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | RandomDeception (10-01-2015) |
#2966 |
Drives: 2023 BRZ
So what do you think happens to the car when the "temps go crazy"? Would the average driver even know anything is different/not right? Do you think the engine would blow up or something?
#2967 |
Dismember
Drives: 2013 Red Scion FR-S
I can't imagine a problem running steady at 120. Ask a German.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | RandomDeception (10-01-2015) |
#2968 |
/scion
Drives: '13 86 M/T
The OEM oil cooler conversion seems pretty enticing. Would you recommend skipping that option and going with an aftermarket oil cooler setup, if the car will see occasional track use?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
