#281 |
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
@Td-d, what's changes have you made? Also Can you check on idle stability ? Do you already have the x and y for logging?
Sent from my iPad using Tapatalk |
#282 |
Here's the link to notepad plus http://notepad-plus-plus.org/download/v6.6.9.html
My versions gonna get updated today, seem mine's quite outdated now at 6.1.3, May 28 2012 build LOL |
#283 |
Do we have logging addresses for B01D? I've acquired an OP2 and would love to use it for logging
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#284 |
Drives: 86 GTS
Back on 98 as E85 locations were getting too hard and the economy wasn't great.
First 2 logs: http://www.datazap.me/u/tech86/98-stage-1 3rd log split in 2 for size limit. http://www.datazap.me/u/tech86/98-stage-1-0 Any comments? |
#285 | |
which 98 are you using BP seems worse than shell for knock on these cars. fuel trims afr look ok. |
#286 | |
Drives: 86 GTS
LOL BP stands out that much but yeah, was the closest servo at the time.Yeah happy with the trims, still using stock A01G MAF scale so not sure I need to touch them just yet. |
#287 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#288 | |
However if you try Caltex or Shell fuel you probably wont need to remove that timing. |
#289 |
Drives: 86 GTS
Good point. Still got a near full tank so I'll back it off for now and reload the current map with different fuel. P100 would sort it out no doubt, but I heard they were discontinuing it?
#290 | |
#291 |
Where do they get posted to? I can't find them in github.
#292 |
Normally in Steve's main Tactrix thread - I haven't set up a Github directory for it yet. Probably should.
#293 | |
![]() I've tried to run the logcfg.exe for myself and it appears to be written for a very specific RomRaider configuration that I don't have. Otherwise I'd just create it myself. Going to have a look at the .xml files and see if I can just rewrite the program quickly.
#294 |
I'll get to it this weekend Phrosty - I looked, hadn't posted up yet.
Logcfg won't work because it relies on the master logger.xml that RR logger uses, with its standard notation for the parameters (E_XXX - e.g. E_AF_Correction_1_4byteExt_E81). We need to generate a whole new set of parameters in this syntax to work for Romraider - I just haven't had the time... |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
