Old 07-17-2013, 12:53 AM   #281
wrxgoose
WUB WUB
Drives: 2013 Firestorm
[ame="http://www.youtube.com/watch?v=aX2-cmUyy7w"]2nd gear pull Supercharged FR-S - YouTube[/ame]
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Alabang 86 (07-20-2013)
Old 07-17-2013, 01:19 AM   #282
Dezoris
Dezoris's Avatar
Originally Posted by wrxgoose View Post
If any innovate owner has pulls in 2nd from 3000RPM to redline and 3rd please post them.
I don't know about the variance in dynos but I just compared your clips side by side with cars showing 212HP and 190TQ on a dynojet and your 2nd gear pull is almost identical, certainly not 30HP more.
So keep that in mind you maybe at the limit based on those numbers but I think at least on dynojet and mustang you are under.
Old 07-17-2013, 01:23 AM   #283
Dezoris
Dezoris's Avatar
Originally Posted by whataboutbob View Post
I'm looking at some of my logs and interested to know what are considered "safe" AFR values?
11.02 to 11.6 is where it is generally where I see most all of the supercharged logs (ECUtek from 4000-7200RPM)
The Following User Says Thank You to Dezoris For This Useful Post:
whataboutbob (07-17-2013)
Old 07-17-2013, 01:23 AM   #284
wrxgoose
WUB WUB
I do plan on running at the dragstrip again, so that will give some idea of how much faster she is (if I can get traction), And I do think I need to find a nice long abandoned road so that I can really get on it.
edit: and I ment to say that I would love to find another dyno to run on, just to see what it says. Especially if I could find someone with a dynojet around here, I'd definitely go see what it said
Old 07-17-2013, 01:25 AM   #285
whataboutbob
AutoX-10/10ths every run
Ok, so I am a FI n00b. Should I expect to see an AFR spike when I let OFF the gas?
Build thread:Here
whataboutbob is online now   Reply With Quote
Old 07-17-2013, 01:35 AM   #286
nix
nix's Avatar
Drives: AVO BRZ
I use my gf instead of an AF gauge she is scared of back fires and so give a little scream each time...
nix is offline   Reply With Quote
Old 07-17-2013, 01:51 AM   #287
Dezoris
Dezoris's Avatar
When you lift throttle it will spike usually to the max readable by the O2 sensor of about 23.2. In fact anytime you lift it will go lean.
Old 07-17-2013, 01:59 AM   #288
wrxgoose
WUB WUB
best. power. gauge. EVER.
so every time you downshift, she squeaks?
nix (07-17-2013)
Old 07-17-2013, 09:27 AM   #289
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
If you mean lean, then yes. When you lift the ECU shuts off the injectors to conserve fuel.
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 07-17-2013, 09:56 AM   #290
djdnz
1337
Drives: 2013 BRZ WRB S/C
I'd push it up to 250, but i'm worried about the clutch. I'm at 211 lb/ft, and iirc, the clutch is only rated for 220ish
AFR's are brutal, time for a tune.
djdnz is offline   Reply With Quote
Old 07-17-2013, 11:07 AM   #291
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by djdnz View Post
AFR's are brutal
This.
The Following User Says Thank You to King Tut For This Useful Post:
MattF (07-17-2013)
Old 07-17-2013, 11:09 AM   #292
swift996
swift996's Avatar
Anyone running larger injectors/pump?
Mike from Moto-East mentioned on E85 there were some trouble spots for the stock injectors. I'm following his set up so I can install and flash rather than custom tune. However, I'm just curious if anyone has ventured out of the OEM fuel system yet. I know Robi and sw20kosh have replaced the pump.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-17-2013, 12:05 PM   #293
xxscaxx
Drives: 2013 SWP BRZ
I installed the DW 265 pump (did an DIY for it), and I have FIC 540cc injectors sitting in my room. They would have went in when I did the install but they forgot to send me the PnP harness for them so i'm waiting on that.
That AFR reading on the dyno plot is scary..
xxscaxx is offline   Reply With Quote
Old 07-17-2013, 12:09 PM   #294
xxscaxx
Originally Posted by DriftEm View Post
Are these numbers with normal driving or hard driving?
just normal driving. Only time I really get on my car is when i'm datalogging..lol
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
