#281 |
Drives: GT86
That plug does not look like it's seen an excessively lean condition.
#282 |
Drives: BRZ, STI, 535, Tiffin Allegro
It appears everyone is having seal, plug, and coil issues with cylinder one???
Has anyone had a fail on any of the other three cylinders? My 2,3, and 4 seals looked great. |
#283 |
Grip>Slip
i'm getting some slight popping when rev matching on shifts.definitely sounds like it's coming from the exhaust though. Running nameless overpipe/downpipe/hfc and nameless axleback. Stock ECU now.
I'm assuming it is unrelated, but can anyone ease my nerves and confirm? |
#284 | |
Broken plugs, burnt destroyed injectors, damaged engines and coil packs malfunctioning. I can't believe tuning is the single culprit here.
#285 |
Drives: GT86
Coil packs fail on all kinds of engines. It's the mistake that most manufacturers do where they bolt the coil pack to the engine itself rather than running it remote with plug leads/wires.
Det can break plugs. Det can damage injector seals. Det problem fixed by re-cal. End of discussion. |
#286 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | @Art_Mighty (06-29-2013) |
#287 |
Drives: GT86
I'm running it on my car, thanks.
#288 |
Grip>Slip
Want a cookie? It's not available from Subaru (not sure about Scion) in the US. Contrary to your prior assertion, until a fix is made available to us by the manufacturer, it has not been fixed.
#289 |
Drives: Attitude
ft_sjo's just been trolling the DI leak threads for a few days now.../ignore.
#290 |
Drives: GT86
You ladies can club together all you want. Have any of you actually asked Subaru to flash your car with A01 yet?
#291 | |
He said they didn't have that capability - Which we all know is a complete lie. The rep told me the only way to update my ECU was to purchase a new one for $1000. At that point I drove away and haven't been back to that dealer since. |
#292 |
#293 |
Drives: GT86
I find most dealerships a bit shitty. Threaten the parent body with legal action if you're not getting an adequate response.
#294 | |
Drives: 2013 Subaru BRZ
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 07:09 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 01:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 04:25 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
