Old 08-04-2017, 10:03 PM   #281
paolo_86
paolo_86's Avatar
Drives: 2014 Red GT86
132mph on the A8 Autobahn in Germany. Plenty of power left, but had to back off due to slower traffic.
paolo_86 is offline   Reply With Quote
Old 08-04-2017, 10:13 PM   #282
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Originally Posted by Ron B Avery View Post
Coming back from Arizona yesterday down hill a bit. I saw 126 MPH in 6th.
On the way there on a part of the road that was flat. I saw 116 MPH, in 5th.
It took a long time on the flat road and it was just at red line in 5th.
Ron
I red lined 5th at 120mph I think, so I know it's always safe to downshift on the highways. It'd be nice to see how 6th does, though.
carsebuco is offline   Reply With Quote
Old 08-04-2017, 10:34 PM   #283
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Shit, some of you have gone so fast. Here in California I take it to 95 in the middle of the night with no one around. I can't afford a felony. Over 100 is a felony.
I would be so scared to take this car to 140+ without some serious proven real air effects. One bump, tire problem, and you are a statistic.
Old 08-05-2017, 04:07 AM   #284
paulca
Drives: Toyota GT86 Coupe Red (UK)
I call bullshit on anything over 140 in a stock car with stock wheels.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 08-05-2017, 08:08 AM   #285
mrg666
pessimistic skeptic
mrg666's Avatar
So it is bullshit, period.
Old 08-05-2017, 03:16 PM   #286
-Willis-86touge
Drives: Stock
[QUOTE=paulca;2957347]I call bullshit on anything over 140 in a stock car with stock wheels.
Haters going to hate. ! It can ! Do 150 for sure! Any more and it might be grade of terrain helping out. Just because someone can't push past being scared doesn't mean this car and tires aren't capable! Call me a liar all you want but personally hit 155!
-Willis-86touge is offline   Reply With Quote
Old 08-05-2017, 04:28 PM   #287
humfrz
hmmmm....... was the guy in the video on post #276 bullshitting us ...... ??
humfrz
Old 08-05-2017, 04:38 PM   #288
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by nextcar View Post
Pictures or it didn't happen...
I was too subtle in my original post. That disembodied FRS instrument cluster was part of the scattered debris when an FRS was going 140 and hit a light pole and split into 3 pieces.
Anyone who does this level of speed on public streets (autobahn excepted) is driving very, very irresponsibly. I don't mind social Darwinism, but you might just take out some innocent bystanders even if you think no one else is nearby.
/lecture
nextcar is offline   Reply With Quote
Old 08-05-2017, 05:59 PM   #289
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
Don't forget I My 2017 has a lower final drive ratio 4.3 as opposed to 4.1
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 08-05-2017, 11:27 PM   #290
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
I was up in the mountains on I-90 between Spokane and Seattle, topped the car to 134, it felt like it could've kept crawling up faster but I couldn't get a stretch where I felt safe enough to keep going. The stretch after I was accelerating, got to 120, and I see cop lights about a half mile in front of me. That was the quickest I've ever braked from 120 to 70. I was also out in the heat at high altitude, I feel like on a longer road and in cooler conditions, I could've hit the 140 most people talk about being this car's top speed stock.
Borchert97 is offline   Reply With Quote
Old 08-06-2017, 02:52 AM   #291
Somerandom18
Drives: 2017 manual BRZ
It's pretty easy. At sea level. With ambient temps at 70f or below. I don't see why it's hard to believe. What do wheels have to do with anything?
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 08-06-2017, 06:51 AM   #292
paulca
humfrz
Okay, fair point on "indicated" speed. But the stock speedo overreads by around 10%. So his 149 indicated is probably more like 136 actual.
If you don't believe this, look up the mechanical limit of 2nd gear, I believe it is 59.8mph or something similar. Now go and bounce the car off the limiter in 2nd and see what speed it reads, I've seen mine read 65mph. Then check on a GPS.
Wheels/Tyres make a difference, even tyre pressures make a difference. The speedo only counts how many times the wheels go round, via a gearbox sensor and multiply it by the circumference of the tyre. If you put smaller wheels, even by a few mm smaller the speedo will read high. Even worn tyres can add a few percent to your indicated speed. If you changed your wheels and tyres and did not match the sizes exactly to achieve the same total circumference of stock your speedo is now inaccurate. In the UK insurance companies get awful annoyed about this and refuse to pay in some circumstances.
As I worked out on another thread. The difference in horse power between 139 and 160mph is 64bhp! The car needs 264bhp to do 160mph. That is assuming the 139 is it's genuine max actual speed.
You see adding 10mph here or there is not a small thing at top speed. Every mph needs more and more power. The simple rule is, to double the speed you need 4 times the horsepower. Anyone with a basic college education can rearrange that to work out the horse power difference needed to change their vmax by a given amount.
A down hill will not make as much difference as a tailwind would. Air resistance is such a big factor that mechanical drag is all but negligible at top speed.
With that said, in theory with a constant 20 mph tailwind I suppose 150 might be achievable. However finding such a steady wind that would allow the car long enough to accelerate to 150 is going to be very hard to find.
Old 08-06-2017, 12:21 PM   #293
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
This. Once you hit 120, the car crawls. I've taken mine when it was stock to about 130, but small hills/bumps were ahead and sketchy. It could have kept going, but not worth. I was about a foot above sea level, 85*f in high humidity. I'd gladly do another run to try and max it, but i'm modified now.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 08-06-2017, 01:26 PM   #294
Ultramaroon
not playing cards
Ultramaroon's Avatar
I agree with your conclusion regarding your own speedo but disagree with the generalization. By all verifiable techniques, mine is dead on.
I've pulled 112 on the front straight at PIR. That's plenty fast enough for me.
Engine Speed vs Vehicle Speed for 6MT DetroitJake Engine, Exhaust, Transmission 22 04-27-2013 06:56 PM
Need For Speed... Really? Texas BRZ Tracking / Autocross / HPDE / Drifting 61 01-11-2013 11:59 PM
Top Speed L3P47 Scion FR-S / Toyota 86 GT86 General Forum 6 12-18-2012 12:06 AM
top speed JLMtm Scion FR-S / Toyota 86 GT86 General Forum 56 10-30-2012 09:23 AM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
