Old 11-20-2019, 01:23 PM   #281
humfrz
My go-to is hydroxic acid.
Is that like hydroxamic acid?
If so, maybe that was in the mix during my chemo therapy?
And so, you see how I am now -
humfrz
Old 11-20-2019, 01:26 PM   #282
humfrz
OMG, you beat me to it!
Well, maybe I used it, but I didn't keep a 5 gallon can of it in my garage - like some did -
humfrz
Old 11-20-2019, 01:51 PM   #283
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
humfrz
No, this is far worse. If you don't know of it, it's a colorless, odorless chemical with a number of used including cooling industrial equipment, stripping paint, enhancing agricultural growth, and fire suppression.
Some of the fun bits: Inhaling it has been known to cause suffocation, and prolonged exposure can cause severe tissue damage. It's also extremely corrosive and discarded quantities do millions of dollars in damage to infrastructure every year. Due to not being a controlled substance, some ingest it in small doses to enhance performance. There's no test for it, so anyone could be on it and you wouldn't know.
Old 11-20-2019, 02:39 PM   #284
humfrz
OK,OK - you had me there -
humfrz
Old 11-20-2019, 02:42 PM   #285
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I have a hydrofluoric acid story from back in the early 80's...I was just a dopey high school kid washing cars at the local VW dealership, and our equally dopey chemical supply delivery guy dropped off a 5 gallon pail of the stuff one day and said "Here, try this.. it works AWESOME on dirty wheels, but be sure to dilute it a bit..." End of safety lecture.
It DID work like gangbusters on otherwise hopelessly grungy aluminum wheels, but man, it was some harsh stuff... No protective gear at all, mixed anywhere from 2:1 and stronger, and applied with a spray bottle...mist everywhere, all over our hands, fumes were chokingly strong, etc. It wasn't until I was in college and my organic chem instructor was talking about how bad it really was, that I realized I'd once again narrowly missed the Darwin hammer...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 11-20-2019, 03:47 PM   #286
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Talking
I'm confused how anyone is going through brake pads that quickly. Unless they're doing Tail of the Dragon mountain runs daily (or track their car with stock pads - which is just dumb).
Also those rotors look horrendously bad.
Also also, I'm waiting for someone to tell me how they check pad depth for the inner pad on any car without removing the wheels (or lifting the car into the air). It's impossible. And IME it's usually the inner pads that are thinner from use.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 11-20-2019, 03:51 PM   #287
JD001
JD001's Avatar
Drives: Subaru BRZ
If someone has a habit of resting the left foot on the brake pedal.. a bit like riding the clutch in a manual car...
Old 11-20-2019, 04:14 PM   #288
WolfpackS2k
^perhaps. All I know is I sure as hell wouldn't admit that I wear out my pads in less than 30,000 miles.
Old 11-20-2019, 04:21 PM   #289
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I’ve worn out pads within a few hundred miles.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-20-2019, 04:29 PM   #290
Ultramaroon
not playing cards
Ultramaroon's Avatar
Wow!!! That's horrific!
Years ago I scolded an artistic friend when I found out that she had started dabbling in etching glass with the stuff. Yikes!
Old 11-20-2019, 06:17 PM   #291
GrantedTaken
Mechanix gloves have a purpose, and so do nitrile gloves.
If you don't know the difference, try doing more than debadging cars with floss tools.
Pit crew comment was hilarious!
Get some new wheels, camber boy.
Brake pads?
Jack car.
Remove wheels
Remove caliper.
Remove pads.
All done with thick gloves.
Only step I removed the gloves was to replace the shims.
The other use for cloth gloves is anything that involves grease, oil, lube.
Hassle to keep changing nitrile.
I have 5 pairs of Mechanix and wash each pair after use.
GrantedTaken is offline   Reply With Quote
Old 11-20-2019, 06:24 PM   #292
GrantedTaken
By the way, with new thick pads, I can not see the pads from the outside of the wheel.
So, it was not just a case of low brake pads. Just a crap covered design
Old 11-20-2019, 06:28 PM   #293
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I have not done it on my BRZ but have on other cars. If you get a telescoping mirror and flashlight you should be able to look through the window and see both brakes without taking the wheel off. It’s not perfect but I can usually see enough to make a decision on when I need to get new pads. I also rotate my wheels and always check at that time.
Ernest72 is offline   Reply With Quote
Old 11-20-2019, 07:17 PM   #294
humfrz
Then did you release the emergency brake all the way?
humfrz
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
