#2885 |
Drives: Whiteout FRS
I asked on facebook yesterday and they said they are shooting for febuary in regards to the 335
life's greatest stories usually start with the words, "fuck it!".
#2886 |
Drives: Frs
Wonder what kinda numbers it'll put down and if it'll be a bolt on like the 210 or if engine upgrades will be a must
#2887 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
#2888 |
Drives: 2013 SWP BRZ
I have to fess up and eat some crow, as I said I checked multiple times for leaks and didn't find any. Low and behold today, I found one. It's been so cold here that it was hard to smell/tell. The clamp on the coolant bottle line that connects to the plastic tee was leaking and I somehow didn't see it. Was leaking on the bottom. I repositioned it and tightened it down, so I will check it again but all seemed ok after a few checks. I can't tell if those pre clamped lines are leaking at all on the tee but I cleaned the area up and will check again next drive out. Thanks for following up. |
#2889 | |
#2890 | |
Drives: Toyota 86 RC
my friend car it also leak here! very bad design!
#2891 |
#2892 |
Road Warrior
Here are our test results from today on our dyno
Firstly the dyno is a Inertia dyno with 0 correction factor and does not give happy numbers So I received @DeliciousTuning new tune which allows to change from 75mm down to 70mm. Bill has not received any logs to review tune on my car, so I mention this, as I noticed some timing being pulled at top maybe due to safety factor. Sent in logs to correct. I don't think I have seen these results posted yet all done same day on same dyno, Sprintex Intercooled kit. All runs on 95 Ron = 91 Oct My stock dyno run 154whp 135ftlb 75mm = .68 bar boost = 217whp 188ftlb 72.5mm = 0.73 boost = 225whp 189ftlb 70mm = 0.8 boost = 231whp 196ftlb The above was done on the coast, summer conditions extremely hot today 36 deg c, so possibly lost 10% power due to the heat factor. Mods if you would be interested HKS intake duct AFE pro dry DIF Borla UEL 63mm overpipe 63mm performance exhaust, I added a small HPC to front pipe for noise reduction Hope this info helps. |
#2893 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#2894 |
Road Warrior
Our dyno is a loading inertia dyno. 0 correction factor.
Im sure Bill will apply his magic. |
#2895 |
Based off your stock run your dyno might read about 4% lower than our US DynoJet.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2896 | |
PhoneFlash by EcuTeK
Ryan, I hate to say it is really picky when it comes to the tune and I love it. It really forces me to dial the tune. So I am working with Ryan to make sure the tune is ONLY better then the previous tune. Though the power numbers are what I would expect the low end light throttle from a dead sport have gone a little in the wrong direction. So I need to perfect this before releasing the tune to everyone else. Thanks for the info Ryan. Cheers, William Knose |
#2897 |
Grip>Slip
naaawce. I should be to a point where i can start datalogging and getting my intercooler tune tweaked. also considering a flex-fir...er..fuel kit. who do you guys recommend for hardware?
#2898 | |
That Guy
Drives: 2013 asphalt FRS MT
Harness to plug into the sensor, probably have to hack off the end you wont use. http://www.gmpartsdirect.com/results...umber=13352241 Long tube sensor http://www.gmpartsdirect.com/results...umber=13577394 Short tube sensor http://www.gmpartsdirect.com/results...umber=13577379 Push on adapter http://www.summitracing.com/int/part...4120/overview/ |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
