Old 01-21-2014, 09:27 AM   #2787
swift996
swift996's Avatar
With so much emphasis on the circulating pump. I'm wondering if any of the electrical inclined might recommend a way to wire up a little LED light to the pump wiring? Sort of like when you check for a connection on a wire. I was thinking just running a tiny LED into the cabin so you can see the pump is working. It would only light up when the pump is on. Make sense?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-21-2014, 10:09 AM   #2788
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Unless you're using something like a flow switch or a current sensing switch the LED will simply tell you that the pump SHOULD be on. You already know that because the car is running.
I think you'd notice pretty quickly that you were down on power and heat soak was becoming a problem if your pump wasn't flowing.
Sellout is offline   Reply With Quote
Old 01-21-2014, 10:10 AM   #2789
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by xjohnx View Post
well that's good news. I'll reflash it this afternoon and see if she starts up. does anyone know if it's safe to drive without the coolant circulating? My parents house is about half a mile away and they have the warmth of a garage that would make bleeding the coolant much easier.
Pop the fuse out of the power wire leading to the pump. Running the pump without fluid could kill it.
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 3 Users Say Thank You to civicdrivr For This Useful Post:
Calum (01-21-2014), swift996 (01-21-2014), xjohnx (01-21-2014)
Old 01-21-2014, 10:43 AM   #2790
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
A thought, run the light wire for the boost gauge to the pump fuse, so light on the boost gauge, pump working, light not on, know pump not working..
Ryan86 is offline   Reply With Quote
Old 01-21-2014, 10:45 AM   #2791
Ryan86
Road Warrior
Ryan86's Avatar
Yeah it's valid. Usually when people force induct a car they add a colder spark. From what I remember you have to basically drop the engine to change them. I could be wrong.
Any idea which would be the plug to use?
Old 01-21-2014, 02:18 PM   #2792
Calum
That Guy
Drives: 2013 asphalt FRS MT
If there isn't a relay between the fuel injector power circuit and the pump then the only thing that will tell you is that the injectors (and pump) are being powered. Well, if the car is running you can probably bet the fuel injectors are being powered. As was mentioned a flow switch or a pressure switch would be the only way to really accomplish the goal here.
Old 01-21-2014, 02:40 PM   #2793
Ryan86
Road Warrior
Ryan86's Avatar
I'm advised these are the correct plugs to use with SC
NGK LFR7AIX 2309 NGK Iridium IX spark plugs
Old 01-21-2014, 03:17 PM   #2794
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Most people actually raise it up, and as far as I am aware there are no affordable colder spark plugs so I would recommend just closing the gap a little bit.
Old 01-21-2014, 04:19 PM   #2795
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Time for a new tune! Who are you all using and how is the tune you're on?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 01-21-2014, 04:35 PM   #2796
xjohnx
Grip>Slip
xjohnx's Avatar
Using @DeliciousTuning and couldn't be happier.
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
calispec (01-21-2014), evo4g63 (01-21-2014), Ryan86 (01-21-2014)
Old 01-21-2014, 05:03 PM   #2797
phloozy
phloozy's Avatar
Drives: Scion FR-S
@moto-mike and super happy
phloozy is offline   Reply With Quote
Old 01-21-2014, 05:10 PM   #2798
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Getting my Sprintex kit fitted next week plus custom Perrin oil cooler.
Great thread.
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 01-21-2014, 10:29 PM   #2799
Ryan86
Road Warrior
Ryan86's Avatar
These NGK Iridium +1 are $26 to $46 for 4 plugs. However chat to your tuners, mine says don't need to change to colder plug.
Old 01-21-2014, 10:43 PM   #2800
wrxgoose
WUB WUB
Drives: 2013 Firestorm
I'm using @JuniorAWD, and it's amazing. Just look at the dyno charts I've posted and you'll see why I love it.
Sent from my VS840 4G using Tapatalk
wrxgoose is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
