Old 12-21-2015, 08:05 AM   #267
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Lynxis View Post
Sounds like your tune may be getting in the way and making launching more difficult. I've heard other people complain that launch control is actually not as fast as launching yourself so I'd see if you can disable it. Besides that, you might do better with partial throttle to get your rear tires to hook up quickly then give it the beans.
Also, shifting technique plays a big part too. Gently push the shifter towards the next gear (not hard enough that it goes to neutral) then kick the clutch to get the shifter to move to the next gear. This is a very quick shifting technique. You can also try powershifting which is the same technique except that you keep your right foot flat on the gas while you shift. Note it is extremely hard on your car and you might break something but it's the fastest way to shift.
Finally, better tires are a good idea. I know PSS has good lateral grip but no idea about traction. They're a fairly hard compound so I doubt it's great. Something like RE71r will probably hook up better but I honestly know next to nothing about drag tires.
Any new Track updates????
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-21-2015, 10:55 AM   #268
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Originally Posted by FRS Justin View Post
Don't use launch control feather the gas, then quickly and controlled let the clutch out roughly 1 to 1.5 seconds to full release. When clutch is going out gas should be going down.. Rpms for you I would guess between 3000 and 4k would be a good range to feather at. Drop tires down to 15 to 20 psi and drive thru the water onto dry pavement burn them until they smoke let off brake during burn out half throttle burn out until it hooks then stage. The perfect launch you will be scrubbing the tires thru first gear if they do spin it shouldn't more than 5 ft
Like this
I can launch at 7800 rpm on drag radials and pull a 1.8 60ft time doing this method just takes practice.
As i said before those na times are awesome
The Following User Says Thank You to NyC Zn6 For This Useful Post:
FRS Justin (01-15-2016)
Old 12-21-2015, 11:06 AM   #269
FRS Justin
Thank you very much,
710whp
Old 12-21-2015, 02:38 PM   #270
FT86RGV
Followed some of your advice and was able to improve my 60' by ~.15 which dropped me down to nearly a 13 flat. Was like my sixth run so I stopped after that. also hit a couple 13.1xx and 13.2xx.
Not sure when I'm going back so don't know if 12s will ever happen. We'll see.
FT86RGV is offline   Reply With Quote
The Following 3 Users Say Thank You to FT86RGV For This Useful Post:
FRS Justin (12-21-2015), icybrzzz (12-22-2015), NyC Zn6 (12-21-2015)
Old 12-21-2015, 02:52 PM   #271
FRS Justin
3/10 is a awesome gain from just changing how you do things. That's something to be proud of seriously, don't let anyone tell you different.
You started needing over 3/10 to hit 12s now you need .024 thousandths. You could get that by taking the floor mats, owners manual ect. out of the car, I assume the spare and jack are removed. Or even burning some gas out of the tank. .023 is less than a eye blink. less than 1 flat foot speed shift. It is a mid 12s ride. PM me when you have time maybe I can help. I need to know what the car did.
710whp
Old 01-07-2016, 10:46 AM   #272
Dream20b
Y u do dis?
Has anyone beat 12.89 on a sprintex 210 kit yet?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 01-10-2016, 02:18 AM   #273
FT86RGV
on street tires and without significant weight reduction that's probably about the limit although I'm going again this Wednesday to try to hit 12s myself so I'll update my time later. The other guy and I both had flexfuel and small pulley so we should be making similar power (my guess ~280-290 rwhp) and maxing out the kit.
With slicks or possibly drag radials there should be no problem hitting somewhere around 12.5-12.7 with the kit. But that's pretty much going to be the best I think without taking weight out.
Old 01-10-2016, 02:52 PM   #274
Dream20b
Y u do dis?
I ran that on all season tires so i think I could see very low 12s or even 11s with a slick.
Dat Hot Lava Doe
Old 01-10-2016, 05:04 PM   #275
FT86RGV
That would be fantastic but 11s would be a big stretch imo. With a proper drag setup (suspension/tires) I could possibly see low 12s happening.
Of course if you could prove me wrong that would be great that way I have something to shoot for myself.
The Following User Says Thank You to FT86RGV For This Useful Post:
Dream20b (01-11-2016)
Old 01-11-2016, 12:42 PM   #276
Dream20b
Y u do dis?
My ET was 12.89@110, so the MPH is there.
Dat Hot Lava Doe
Old 02-02-2016, 03:31 AM   #277
BostonDave91
Drives: 2016 frs
What size rims are you using I was thinking 17×7.5 front and 17×9 for the rear. Is 265 35 17 a good rear tire size
BostonDave91 is offline   Reply With Quote
Old 02-04-2016, 05:06 PM   #278
FT86RGV
Good and Bad Day!
So I finally got in my new Hoosiers DOT Drag Radials V. 2 (pretty much slicks) in 245/45/17. Mounted them on some cheap 17 x 8 rims. Took them to the track last night and they are absolutely amazing.
Mods are: Sprintex 210 intercooled kit - 69 mm pulley, airaid intake, flex-fuel tuned by delicioustuning. Revworks headers, invidia overpipe, front pipe, and Q300 catback.
Before the hoosiers I had a hard time launching the car. pretty much had to launch below 3k rpm to hook with the street tires I had on before (265/35/18 pss). Was hitting 12.9xx - 13.1xx.
I decided to launch at 4k rpm with the hoosiers. 1st run - 12.653 @ 108.97 / 60' 1.920.
They hooked so well there was no spin and the car still bogged down
2nd run: 4.5k rpm - 12.678 @ 110.30 / 60' 1.864. Same issue as 1st run.
3rd run: 5k rpm launch. I am #33 right side.
Car felt very quick out of the hole. Was amazing. nearly hit 7s in the 1/8. Had just a tad of wheel spin but tires hooked after a few feet and I flew.
The bad:
Was about to call it a day and wait but decided one more. why not?
4th run: 5.5k rpm launch - dnf. As soon as I dumped the clutch really loud pop out back. Car sat in place and didn't go anywhere. had to be pushed off to the side.
First thought was driveshaft or differential. Ended up being driver side cv axle. I completely snapped it. broke at the hub end. You know what they say. Gotta pay to play. Will be ordering Driveshaft Shop 600 hp rated axles. hopefully can get them in next week and installed by next weekend. @FRS Justin @Dream20b
The Following 4 Users Say Thank You to FT86RGV For This Useful Post:
Dream20b (02-04-2016), FRS Justin (02-04-2016), raven1231 (02-04-2016), Starkiller (02-18-2016)
Old 02-04-2016, 05:26 PM   #279
Dream20b
Y u do dis?
I bet you could get a 1.6 out of your 60' and nock it down to 12.2 or 12.1
Also what did you race
Dat Hot Lava Doe
Old 02-04-2016, 05:45 PM   #280
FT86RGV
yeah that's what I thinking but I won't be racing for a couple weeks probably. I didn't think the axles would be that weak.
honestly the 12.460 wasn't the best. I could tell right away there was still a lot of improvement left in there so you were right. low 12s is doable
I raced a brand new 2016 v6 mustang.
Scion's free 2 year/25K mile maintenance plan? whtchocla7e Scion FR-S / Toyota 86 GT86 General Forum 25 06-06-2012 04:26 PM
La Times reviews BRZ Sport-Tech BRZ First-Gen (2012+) — General Topics 7 05-18-2012 12:11 PM
He lives his life 1 quarter mile at a time ucla bruin Other Vehicles & General Automotive Discussions 8 12-21-2011 08:04 PM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Louie Southern California 1 10-11-2011 01:31 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Louie Southern California 2 03-20-2011 06:17 AM
