#267 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#268 | |
Drives: 10 Series #974 6m/t
| The Following User Says Thank You to NyC Zn6 For This Useful Post: | FRS Justin (01-15-2016) |
#269 |
Thank you very much,
#270 |
![]() Followed some of your advice and was able to improve my 60' by ~.15 which dropped me down to nearly a 13 flat. Was like my sixth run so I stopped after that. also hit a couple 13.1xx and 13.2xx. Not sure when I'm going back so don't know if 12s will ever happen. We'll see. |
| The Following 3 Users Say Thank You to FT86RGV For This Useful Post: |
#271 | |
You started needing over 3/10 to hit 12s now you need .024 thousandths. You could get that by taking the floor mats, owners manual ect. out of the car, I assume the spare and jack are removed. Or even burning some gas out of the tank. .023 is less than a eye blink. less than 1 flat foot speed shift. It is a mid 12s ride. PM me when you have time maybe I can help. I need to know what the car did.
#272 |
Y u do dis?
Has anyone beat 12.89 on a sprintex 210 kit yet?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#273 |
on street tires and without significant weight reduction that's probably about the limit although I'm going again this Wednesday to try to hit 12s myself so I'll update my time later. The other guy and I both had flexfuel and small pulley so we should be making similar power (my guess ~280-290 rwhp) and maxing out the kit. With slicks or possibly drag radials there should be no problem hitting somewhere around 12.5-12.7 with the kit. But that's pretty much going to be the best I think without taking weight out. |
#274 | |
Y u do dis?
Dat Hot Lava Doe
#275 | |
Of course if you could prove me wrong that would be great that way I have something to shoot for myself. |
| The Following User Says Thank You to FT86RGV For This Useful Post: | Dream20b (01-11-2016) |
#276 |
Y u do dis?
My ET was 12.89@110, so the MPH is there.
Dat Hot Lava Doe
#277 |
Drives: 2016 frs
What size rims are you using I was thinking 17×7.5 front and 17×9 for the rear. Is 265 35 17 a good rear tire size
#278 |
Good and Bad Day!
So I finally got in my new Hoosiers DOT Drag Radials V. 2 (pretty much slicks) in 245/45/17. Mounted them on some cheap 17 x 8 rims. Took them to the track last night and they are absolutely amazing. Mods are: Sprintex 210 intercooled kit - 69 mm pulley, airaid intake, flex-fuel tuned by delicioustuning. Revworks headers, invidia overpipe, front pipe, and Q300 catback. Before the hoosiers I had a hard time launching the car. pretty much had to launch below 3k rpm to hook with the street tires I had on before (265/35/18 pss). Was hitting 12.9xx - 13.1xx. I decided to launch at 4k rpm with the hoosiers. 1st run - 12.653 @ 108.97 / 60' 1.920. They hooked so well there was no spin and the car still bogged down 2nd run: 4.5k rpm - 12.678 @ 110.30 / 60' 1.864. Same issue as 1st run. 3rd run: 5k rpm launch. I am #33 right side. ![]() Car felt very quick out of the hole. Was amazing. nearly hit 7s in the 1/8. Had just a tad of wheel spin but tires hooked after a few feet and I flew. The bad: Was about to call it a day and wait but decided one more. why not? 4th run: 5.5k rpm launch - dnf. As soon as I dumped the clutch really loud pop out back. Car sat in place and didn't go anywhere. had to be pushed off to the side. First thought was driveshaft or differential. Ended up being driver side cv axle. I completely snapped it. broke at the hub end. You know what they say. Gotta pay to play. Will be ordering Driveshaft Shop 600 hp rated axles. hopefully can get them in next week and installed by next weekend. @FRS Justin @Dream20b |
| The Following 4 Users Say Thank You to FT86RGV For This Useful Post: |
#279 |
Y u do dis?
I bet you could get a 1.6 out of your 60' and nock it down to 12.2 or 12.1
Also what did you race
Dat Hot Lava Doe
#280 | |
yeah that's what I thinking but I won't be racing for a couple weeks probably. I didn't think the axles would be that weak. honestly the 12.460 wasn't the best. I could tell right away there was still a lot of improvement left in there so you were right. low 12s is doable I raced a brand new 2016 v6 mustang. |
| The Following User Says Thank You to FT86RGV For This Useful Post: | Dream20b (02-04-2016) |
| Scion's free 2 year/25K mile maintenance plan? | whtchocla7e | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 06-06-2012 03:26 PM |
| La Times reviews BRZ | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 7 | 05-18-2012 11:11 AM |
| He lives his life 1 quarter mile at a time | ucla bruin | Other Vehicles & General Automotive Discussions | 8 | 12-21-2011 07:04 PM |
| $95 Track day at Willow Springs- Horse Thief Mile-Oct 16th | Louie | Southern California | 1 | 10-11-2011 12:31 AM |
| $85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal | Louie | Southern California | 2 | 03-20-2011 05:17 AM |
