Old 09-01-2012, 07:40 PM   #267
xcelir8brz
Drives: 2013 BRZ Limited
I've measured about 10F degrees reduction with snorkel removed.
xcelir8brz is offline   Reply With Quote
Old 09-01-2012, 07:45 PM   #268
xcelir8brz
I thought I'd provide another update. I was 'away' from my car for over a week. No problems, went to San Francisco for a convention.
Anyhow, when I returned, I got into the car, let it warm up and drove it.
I still have my CAI V2 sound ingrained into my memory of how it sounded and felt, but less so, now being away from the car for a week and having a fresh drive. Honestly, I have to get used to this hoover vacuum cleaner intake sound, but as I mentioned before, it's staying on the car.
No performance issues with the car as well. Thanks so far. Cross the fingers.
The Following User Says Thank You to xcelir8brz For This Useful Post:
AJUSA.com (09-04-2012)
Old 09-01-2012, 08:23 PM   #269
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
freshly installed
Going to drive around to give feedback.
Tylub is offline   Reply With Quote
Old 09-01-2012, 08:35 PM   #270
Minetious
Drives: 2012 Subaru BRZ LTD WRB
Thanks for the tshirt! I was expecting a generic one but it has a nice design and quality. Sportin Airaid!
Minetious is offline   Reply With Quote
Old 09-01-2012, 08:54 PM   #271
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Question
Just got my hat and $50 from Airaid! Thanks!
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-02-2012, 01:15 AM   #272
Tylub
Tylub's Avatar
The drive was nice. I recommend thr sound generator delete as after 6000 rpm is ridiculous. It feels like I lost some low end torque but I get more out of the powerband. Also when I press on the gas pedal, I meed to press more than usual to go but I like it, its less sensitive so I can control it better. Overall great product!
Old 09-02-2012, 02:10 AM   #273
W2
W2's Avatar
Drives: Firestorm FR-S
Wow that's quick! I sent my forms in the middle of this past week, I kept procrastinating about getting them in the mail.
W2 is offline   Reply With Quote
Old 09-02-2012, 11:34 AM   #274
Brzce
Brzce's Avatar
Drives: WRBP BRZ Limited - Manual
Originally Posted by Foobar View Post
OK, I sent David@AIRAID a PM, but in the meantime, I assessed the Barb Elbow and the Intake Tube and determined that the Barb Elbow is actually the right size as described in the packing list and instructions. The Intake Tube has a 1/8th threaded opening while the Barb Elbow has a 1/4th threaded nipple.
Those of you with the correct fitting parts, which is correct, is the elbow supposed to be 1/8th or 1/4th? For now, I reduced it with a 1/4 -> 1/8th adapter and a 1/8th male/male nipple as shown below.
EDIT: Just spoke to Ben @ AIRAID and it appears the tube itself has the incorrect threading. They're shipping out a new tube to me ASAP. Not sure if my reduction hack is going to cause some performance issues or other problems, so I'm just going to keep the car off the road until I get the new tube in place. Thanks to the folks at AIRAID for the quick response!
Also - at first I couldn't figure out how the firewall plug was supposed to be installed. It turns out you have to remove the stock grommet completely, then push the firewall plug in from the engine side and give the center part a good push until you feel it click.
At first I wasn't pushing it hard enough and it kept falling out, so then I tried it with the stock grommet and that didn't really work either. Then I tried different permutations from engine side as well as cabin side.
I've got the wrong elbow / tube threading also. Thanks to those that mentioned checking kit contents prior to install!! I believe that a 1/4" NPT tap should fit this port instead of a 1/8" NPT.
Airaid 511-307 Intake - installed 08sept12
Brzce is offline   Reply With Quote
Old 09-02-2012, 01:14 PM   #275
Keith@AIRAID
Drives: 51 Kaiser, 97 4Runner, 07 Civic Si
That is correct. The fitting is 1/4" NPT and the hole should be too. All of the tubes with the 1/8" NPT holes should be isolated and corrected by now.
Keith@AIRAID is offline   Reply With Quote
The Following User Says Thank You to Keith@AIRAID For This Useful Post:
Brzce (09-02-2012)
Old 09-02-2012, 01:28 PM   #276
2forme
I just posted my bogging update and other pics in the bog thread. But here's my install picture.
Old 09-02-2012, 04:15 PM   #277
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by rasec29 View Post
Noticed the cover screws get loose and 1 fell out somewhere.
My buddy pointed out to me that one of mine was missing too
David@Airaid- Would it be possible for you to mail me an extra screw when you mail my rebate? I'm just really anal about these things and need all the screws to match or I would have just slapped one in from my parts bin and called it a day.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-02-2012, 04:21 PM   #278
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
i'm missing one too
xclusive_brett is offline   Reply With Quote
Old 09-02-2012, 04:55 PM   #279
2forme
I'm missing 2, my install pic is from a couple weeks ago
Old 09-02-2012, 06:52 PM   #280
bakerr6
Drives: 2013 raven black fr-s
I talked to david and will be installing my intake hopefully sometime this week. I had some issues with the installation, which they are taking care of
bakerr6 is offline   Reply With Quote
Official Hawaii Pictures Thread touge-n00b Hawaii 172 08-24-2014 11:15 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 08:27 AM
Airaid Intake System Official GB - The pre-order AJUSA.com Engine, Exhaust, Bolt-Ons 212 09-19-2012 07:36 PM
Does anyone have pictures of TRD intake Pekingduck Engine, Exhaust, Transmission 2 04-26-2012 11:37 PM
