Old 01-22-2019, 03:49 PM   #15
kch
Senior Misanthrope
kch's Avatar
Do you mind sharing the specs on your alignment? I'm hoping to change mine soon to -3.2 f and -2.6 rear.
Front: -3.4 camber, 0 toe, max caster (around 6.8)
Rear: -2.2 camber, 0.2 toe
Edit: I'm about to install some SPL FLCAs, which will let me play with the numbers a bit more. But those are the specs I've used for a couple years now.
The Following User Says Thank You to kch For This Useful Post:
Leonardo (01-22-2019)
Old 01-22-2019, 04:00 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks!
SPL parts are nice! Are you max camber in the front now? Also, do our cars have OEM caster adj?
Thanks again!
I LIKE TIRES!
Old 01-22-2019, 04:22 PM   #17
kch
Senior Misanthrope
kch's Avatar
Thanks!
Thanks again!
No, could get a few more tenths in the front on my current setup, but I still daily the car and don't want to get *too* crazy. And no OEM caster adjustment. I'm using raceseng cascam plates.
Old 01-22-2019, 04:40 PM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks! I figured as much about the caster adj.
I recently replaced a bunch of suspension parts... I look into how to add caster more.
I don't want to get Too Crazy either. It happens sometimes though.
Thanks again!
I LIKE TIRES!
Old 01-28-2019, 11:18 PM   #19
Decep
Drives: 2013 FR-S Series 10
any excessive wear due to running that much camber at highway speeds/straight line cruising?
Old 01-29-2019, 12:33 PM   #20
kch
Senior Misanthrope
kch's Avatar
Nope. Toe ruins tires more than camber, and I'm zeroed out in the front.
Leonardo (01-29-2019)
Old 01-29-2019, 12:38 PM   #21
Leonardo
Country Boy 4 Life
Leonardo's Avatar
That's good to know! Thanks!
I was curious about -3 or more camber in the front...
I knew that -1.5 front and -2.2 rear didn't cause any uneven wear, as I have had those specs for 65,000 miles.
Thanks again!
I LIKE TIRES!
Old 01-29-2019, 12:49 PM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Depends on where most of wear for one happens. If one does 5-10 or more trackdays per year, then camber of -3 is beneficial, as 4/5th of tire thread will be worn on track and if anything, they will wear more even and will last a bit longer.
If one never tracks, or at most 1-2 trackdays, then -3 might be excessive, and imho some -1.5 may be more reasonable.
If one does more then 10 trackdays, i doubt any tires will last longer then that anyway
Old 01-29-2019, 06:06 PM   #23
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I don't think that tracking the car has to do with the amount of camber being reasonable. If the tire wear is acceptable to the owner, then it is by definition "reasonable"
I LIKE TIRES!
Old 01-29-2019, 07:13 PM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
"reasonable" in my book - changes handling to wished, enhances grip, makes wear better. On all these accounts it's different for if car is daily driven vs tracked.
For example - when daily driving (within legal limits) car never sees such side-Gs for tires to flex enough to need lot of static camber to compensate, thus with less camber tire contact patch will be more even/better (for driving mostly straight, in turns taken at reasonable/legal speeds, or when there is lack of grip, eg. when wet/on ice/on snow), resulting better traction when accelerating, better stopping distances, better tire wear. Car also will tend less to "follow" longitudinal road grooves.
On track with high side-Gs you get more even contact patch and more grip with more camber to counter that tire sidewall flex. Faster laptimes, even "track" tire wear, not just chewed tire outer side with rest of tire still having loads of thread left. No "enthusiastic driving"/"fast canyon runs" on public roads will provide those loads, unless one goes at 2-3 times posted speed limits, endangers himself and others on road and such.
After i did my first 5 track days, i had worn around 3/4ths of total tire thread, even if total mileage on track was just small portion of daily driven mileage on public roads.
Due all that above is why i "link" advisable/"reasonable"/best chosen camber when doing alignment to amount car gets tracked. Most wear happens on track - choose more track oriented alignment. Never or rarely tracking and just ramping up tens of thousands miles on daily driven public roads? - car benefits more of daily driving alignment if you want to maximize setup.
Of course except wear/handling/performance there can be reasons such as some stance/camber "scene" thing, eg. "hella-camber", or if one chooses unreasonable wheel/tire choice (too wide and/or staggered), and needs that extra camber simply to not rub/clear fender arches & suspension bits. But such are minority, and i don't care much about such reasoning, as for me it's always function over form and i choose specific tires/wheels/alignment settings only for performance/handling/practical (eg. even wear thus money saving) reasons.
The Following User Says Thank You to churchx For This Useful Post:
Old 01-29-2019, 09:10 PM   #25
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So many assumptions... If the word was "Optimal", I would agree with you.
I LIKE TIRES!
Old 01-29-2019, 09:46 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Almost 40k miles on my street tires at -3F, -2R and the amount of camber wear is negligible.
Old 01-30-2019, 04:52 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Excessive toe usually wears down much more. Hence the reason many cars (including ours) have at very least toe adjustment stock. After all, toe = wheel preturned all the time to (toe-in, positive value) or from (toe-out, negative value) centerline, hence it drags tire slightly sideways, increasing wear, even when tracking straight.
Wrong camber for use provides extra wear less. It more affects unevenness of wear, "camber wear". If car tires won't wear much for eg. mentioned 40K miles, then lot of static negative camber won't add much "extra" wear, rather that same wear will be distributed more to tire inside then center/outside, due wheel always skewed a bit sideways. It will "increase" wear mostly in sense, that if one side of tire is down to tire cord, it makes little sense to keep using tire, even if other parts of tire still have lot of thread left, due wrong camber wear.
Bilstein B14 Coilovers: Want to hear some reviews about ride comfort ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-17-2015 04:12 PM
Ride not as smooth after putting on new wheels B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 85 05-19-2014 11:21 AM
For those who ride, there's a group ride happening tomorrow if you're interested. Yamaha_R6 Northwest 3 03-07-2014 10:32 PM
Best Coilover Closest to Stock Ride Comfort? taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 09-04-2013 02:19 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 04:40 AM
