#15 | |
Fast enough
Drives: 2013 Subaru BRZ AT
Show me an example of what you are describing. How can an engine increase in RPM? Engine power DRIVES the supercharger. Without additional engine power applied, the supercharger does not accelerate anything. I'm serious. Show me a link or datalog of ignition cut and RPM's going over the specified rev limit. You cannot have acceleration without force. Force is generated with engine power. |
#16 |
Drives: Late 2014 Subaru BRZ
Ya watch your dash. the TC/SC light flicker as its not your trans... its Time for better tires.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#17 |
I can't punch first or second with the factory tires. Even third breaks loose. These factory tires won't die!
2014 Subaru BRZ
#18 | |
Even with a power/ignition cut, there is still momentum in the climb of acceleration, and the deceleration force from the drag needs a moment to overcome that momentum. You do NOT want to be hitting the rev limiter with a HBP JRSC. Here's some data. Zoomed out, with a spot highlighted. ![]() Zoomed in to the highlighted spot. Note how the clutch is fully depressed, and the transmission is out of gear (on a very obviously grannied shift), and the gas pedal is completely off, yet the RPMs still momentarily keep rising.
| The Following User Says Thank You to CSG Mike For This Useful Post: | whataboutbob (01-11-2016) |
#19 | |
Fast enough
I see the data you are presenting here, and I'll be happy to admit I'm wrong, but I'd love to understand more about how this happens. |
#20 | |
https://en.wikipedia.org/wiki/Jerk_(physics) A slightly longer version, using an example: - At a constant vehicle velocity going forward, you don't feel any force. - At a constant acceleration going forward, you feel the force, but the force itself is "constant" and easy to adapt to. - With a variable acceleration going forward, you'll get thrown around, because you're trying to adapt to a constantly changing force. This is Jerk (change in acceleration). It's also why a lot of people prefer a turbo over a sc; that rapid climb in torque output as the turbo spools, causes a large jerk, while the linear torque output of a SC/NA car has a small jerk. As acceleration is change in velocity over time, jerk is change in acceleration over time. Now, lets translate this back into our example. When you hit the rev limiter, the force causing the acceleration in RPMs is instantly taken away. However, the rate of climb in RPMs, is still present... |
#21 |
Drives: 2015 CWP BRZ Limited
When you clutch in, you've decreased the moment of inertia. Angular momentum is conserved. Angular velocity increases. No force or energy needs to be added to the system to cause a rise in angular velocity.
#22 |
Slow I am, boost I must..
Drives: Whiteout 2013 FRS
Just use manual mode and paddle shift. It's like a manual minus the fun
| The Following User Says Thank You to wise345 For This Useful Post: | 86kahl (01-10-2016) |
#23 |
Drives: 2015 WRB BRZ Premium
@CSG Mike coming in with a calculus lesson!
But seriously, calculus has a lot of uses in system dynamics like situation: Differentiate position with respect to time ->velocity Differentiate velocity with respect to time ->acceleration Differentiate acceleration with respect to time ->jerk Source: Im a Mechanical Engineer, and they beat this sh** into your head in school.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
| The Following 4 Users Say Thank You to Nickosport For This Useful Post: |
#24 |
Angular momentum is conserved. When you clutch in, the complete assembly, which is now disconnected, is also still spinning, except in multiple pieces. The sum of the momentum of the multiple pieces, is still the same as the sum of the pieces connected.
#25 | |
Sometimes I wonder if I should have gone into engineering or computer science or a combination of, because I wonder how much deeper an understanding I would have of these interactions with respect to vehicle dynamics. I'm afraid your post will go over the heads of many people here... :p |
#26 | |
#27 | |
#28 |
| The Following User Says Thank You to jawn For This Useful Post: | Ultramaroon (01-09-2016) |
| Where Do You Set Your Rev Limiter? | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 06-10-2014 05:48 AM |
| Wheel hitting tie rod? | OakmanSmalls | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-16-2013 06:17 AM |
| BRZs hitting Tampa, FL! | FLHC | BRZ First-Gen (2012+) — General Topics | 63 | 07-24-2012 11:20 PM |
| Rev limiter? | feldy | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-03-2012 11:47 PM |
| <3 my rev limiter | NESW20 | Other Vehicles & General Automotive Discussions | 1 | 05-03-2010 12:05 AM |
