Old 03-07-2016, 04:48 PM   #15
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by R2 View Post
Someone did this with Shiv during a dyno day in Texas. The result was Shiv used the Stg2 EL tune and dialed in ignition timing, but unfortunately he didn't make any AVCS changes, likely due to time. The result was a flat torque curve instead of the usual curve you'd expect from the 350.
http://www.ft86club.com/forums/showthread.php?t=91000
As i understand it be made it leaner and pulled some timing. That's it.
Old 03-07-2016, 04:57 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
You needs something like ECUtek to be time efficient on the dyno. Without spending decent time on a dyno it will be hard to dial in cam settings, if you had to flash every change you would easily need to flash at least 10 times, more time than what's available on a dyno day....
.: Stealth 86 :.
Kodename 47 DJ:
Open source Over Boost Fuel Cut ztan Software Tuning 19 02-15-2026 01:32 AM
Open source Hybrid Speed Density ztan Software Tuning 57 07-05-2023 08:33 AM
Open Source Flex Fuel ztan Software Tuning 139 09-24-2021 11:37 PM
Open Source Electric Supercharger neutron256 Forced Induction 913 08-22-2021 05:16 PM
open source software question GeeTee86 AFRICA 15 02-15-2015 06:52 PM
