Old 11-14-2019, 05:37 AM   #15
tomm.brz
Drives: brz 2017 hksv2
that's why I said to take your own responsability
better to have an oil pressure sensor hooked up possibly to the ecu so you can always check it and possibly set up failsafe custom maps
The Following User Says Thank You to tomm.brz For This Useful Post:
gt7877 (11-14-2019)
Old 11-14-2019, 11:38 AM   #16
gt7877
Drives: turbo frs
Originally Posted by tomm.brz View Post
@Rezi
you asked me how to get it in ecutek
i took a stock map as example, if you want ghost cam in Map 4 you do something like this:
there is a little bug that after the engine is started and you enable it, only exhhaust cam go to retarded value
but then you just have to touch the throttle even minimally and also the intake cam will advance and creates more overlap
also raise idle to at least 900-950 and play with idle timings if necessary
do this by yourself, i won't take any responsability
I think this can be done at OFT ROMs at BASE TIMING A coze this used before vvt open
Correct me 😁
gt7877 is offline   Reply With Quote
Old 11-14-2019, 11:40 AM   #17
tomm.brz
Absolutely not, it wont move from 0 with oft without a specific patch
Also ignition timings have nothing to do with cam timing tables
gt7877 (11-14-2019)
Old 11-14-2019, 01:23 PM   #18
toast
Drives: 14 BSP Edelbrock BRZ
If someone throws a big ass wing on a stock car it is called 'rice'. We need a word that is similarly-insulting for purposely making your car idle like shit and waste gas.
toast is offline   Reply With Quote
Old 11-14-2019, 03:21 PM   #19
toast
lol. My wheels are Bronze, you should start with that.
Old 01-16-2020, 02:08 AM   #20
gt7877
Drives: turbo frs
Any update for oft 😅
Old 01-17-2020, 02:43 PM   #21
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
I personally don't care for the afterburn tunes out there, but it doesn't mean my opinion matters. Fireballs out my exhaust is probably a bigger waste than a ghost-cam (which I just learned is a thing 5 minutes ago). Maybe instead of bashing the guy who wants this done to HIS car, maybe appreciate that it can be done in the first place with a "simple" tune.
ROFL it's Waffle is offline   Reply With Quote
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
tomm.brz (01-17-2020)
Old 01-17-2020, 04:31 PM   #22
toast
You're right of course. Callous of me.
Have to get back to researching how I can run -15 degrees of camber.
The Following User Says Thank You to toast For This Useful Post:
ROFL it's Waffle (01-20-2020)
Old 01-17-2020, 05:34 PM   #23
tomm.brz
so funny I almost pissed my pants
Old 01-17-2020, 08:15 PM   #24
toast
Not funny. Everyone should do what they want to their car, right?
Old 01-17-2020, 08:39 PM   #25
tomm.brz
do it then
Old 01-19-2020, 07:42 AM   #26
gt7877
Drives: turbo frs
Toast
Do you feel good!!!!!
Old 01-20-2020, 06:08 PM   #27
toast
Generally. Bit of a cold right now.
Ghost Cam Idle wizzo Software Tuning 26 09-01-2021 10:21 PM
Ghost of Akina's 2013 Firestorm FRS Ghost of Akina Member's Car Journals 3 08-22-2015 02:51 AM
Ghost Car/Dad vividracing Off-Topic Lounge [WARNING: NO POLITICS] 4 07-23-2014 06:51 PM
Ghost Lights DuroSquad Cosmetic Modification (Interior/Exterior/Lighting) 7 07-04-2014 08:14 AM
Ghost's BRZ Build RurumariGhost NY / NJ / CT / PA 5 05-23-2013 10:31 PM
