#15 |
Contract? /人◕ ‿‿ ◕人\
The right tip of the Corsa hangs off a bit to the right off center on my car.
Buds and I tried everything from re-torquing to uninstall > reinstall, playing with the rubber hangers, etc. I said fuck it and called it normal. |
#16 |
Not a troll
And this is why I prefer single exits.
#17 | |
* a friend * 6 pack of beer * blow torch * piece of water pipe with the OD about same as the ID of exhaust Open a beer, set the torch directed at the last bend in the exhaust pipe Finish beer Bend exhaust pipe to desired location while it's red hot Let cool while having another beer CAUTION: shield gas tank from the torch ....... ![]() ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Cole (12-25-2015), soulreapersteve (12-25-2015) |
#18 |
Now that you know where it wants to go...
You can predict which way it will go when you take pressure off of it. First I loosened up the bolts holding the pieces together. Then I sprayed all the rubber hangers with foaming hand soap, so they can move. Using a floor jack, with some rubber floor mat to cushion it, I jacked mine up past where it needs to hang. Then I pulled mine over to the right as far as it would go, because mine was too far to the left. Shaking and wiggling to get the most movement from the loose bolts, I held it as far in the opposite direction, to the way it wanted it to go, and I tightened up the bolts. Then I dropped down the jack, jiggled it back and forth a few times, and got out from under to admire my work.
If I say yes, will that make you think I understand?
#19 |
Drives: blue - Cosworth SC stage 3.0
the stiffer exhaust hangers sold by a few people ( ie Perrin) really help too
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | cdrazic93 (12-25-2015) |
#20 |
Two Days later
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | humfrz (12-26-2015) |
#21 |
So I got myself a helping hand bribed with beer for the whole process throughout and it's aligned perfectly now. I gave the free method one last try before I bought some worm clamps, etc and I think the problem was the positioning of the midpipe->frontpipe. I was using a spare floor jack to hold it in position while I tightened it up originally, having a friend hold it where I wanted it seemed to be the deciding factor in aligning the mufflers in the desired location.
#22 |
![]() humfrz |
| Tips and tricks on driving the car | Mad1723 | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-17-2013 05:22 AM |
| Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? | ScionFR-S | Engine, Exhaust, Transmission | 8 | 12-17-2012 06:39 AM |
| Tips and Tricks for reconditioning your car for trade in? | SteelReign | Other Vehicles & General Automotive Discussions | 17 | 06-04-2012 12:53 PM |
| Tips, tricks, techniques to improve driving? | Buggy51 | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 08-01-2011 05:17 PM |
