#15 | |
#16 |
The traction control. The dash lights sort of mean the opposite to normal when in limp mode. The buttons will not work and the controls are locked on.
#17 |
#18 |
I don't remember reading about anybody that did. You would be nuts to though since if the problem was engine related you could be playing with fire.
| The Following User Says Thank You to Tcoat For This Useful Post: | go_a_way1 (12-14-2015) |
#19 | |
Hit the road and I'm gone
Thank you! I can clear the code this evening and see how it goes.
Slip, slidin' away.
#20 | |
That is exactly what's happening, Tcoat.
Slip, slidin' away.
#21 |
Be interesting to see what it is.
#22 |
CEL code: P0171, A/F mixture too lean. I already know the cause; E-85, which I've been using for a couple of weeks. I richened up the mixture using Unichip standard maps as much as I could, but apparently not enough. As soon as I cleared the code, everything went back to normal.
However, it seems clear to me that (especially in the cooler months) I can't run E-85 all the time. So back to pump gas for now, give this some further thought and study and perhaps in the spring I'll try again. BTW, the triple point of pure ethanol is 150K (-272.15 C or -457.87 F). That is freakin' cold. Its flash point is 16.6 C or about 62 degrees F, which is why you can't have any ignition source around it even at room temperature. Thanks for the advice, all. It did the trick.
Slip, slidin' away.
| The Following 2 Users Say Thank You to babydriver For This Useful Post: | FRSBRZGT86FAN (12-14-2015), Tcoat (12-14-2015) |
#23 | |
#24 | |
![]() Glad it's fixed ..... ![]() humfrz |
#25 |
Glad it was an easy one.
That all explains why E85 is almost unheard of up here. A fuel that does not work well in the cold (I physically chuckled at the thought of what Austin "cooler temperatures" may be) would not be a good idea here. I bet there are not 4 stations that have it within 200 miles of me.
#26 | |
Do you not have 10% ethanol in fuel in canada either?
#27 |
We have 10% yes. In fact it is required for regular gas now. It is just the E85 that is very rare.
#28 |
Actually there are still several brands that have no ethanol in their 91 octane up here. Shell, Ultramar, and Esso to be specific.
| changing the dashboard lights? | JoonPrime | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-01-2014 03:11 PM |
| WTB: Dashboard | markkisl | Want-To-Buy Requests | 0 | 09-12-2014 11:29 PM |
| Dashboard Camera? | DarrenDriven | Electronics | Audio | NAV | Infotainment | 26 | 03-09-2014 04:28 PM |
| FT : my BRZ dashboard for your FR-S dashboard | wrb | Interior Parts (Incl. Lighting) | 2 | 09-25-2013 04:04 AM |
| Dashboard Decals! | PelzerC | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-13-2013 11:31 PM |
