Old 12-11-2015, 08:27 AM   #15
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by mrk1 View Post
Made this myself around what some would call too small of a turbo, GT2860RS, these are rated to about 360hp. I'm at 12psi on 93 octane and its an absolute blast. I helped offset the small wheels with a large AR housing and a 40mm external wastegate.
I have spare stainless manifold flanges if you decide to jump in.
I'm granting you sexy custom setup points. +1
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
mrk1 (12-11-2015)
Old 12-11-2015, 09:38 AM   #16
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
What oil cooler kit are you using? Or is it something you made?
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
mrk1 (12-11-2015)
Old 12-11-2015, 10:10 AM   #17
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Maaad86 View Post
Hey guys, I'm glad I couldn't find this answer, so I'm asking for advice.
I got myself a JDM Toyota CT15B turbo with 60k, now this came out of a stock JDM 1JZ Inline 6, now would it be any good to make this turbo fit into the FA20?
I would be fabricating the manifold and sourcing all other parts, inter cooler piping etc?
Turbo is free so my goal isn't more than 300hp and I do plan on getting a flex fuel kit!
Thanks for your advice
Call Spencer Fabrication in New Hampshire he has done a ton of different turbo setups
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
mrk1 (12-11-2015)
Old 12-11-2015, 10:12 AM   #18
FRS Justin
It's a Mishimoto with custom lines and custom bracket.
710whp
mrk1 (12-11-2015)
Old 12-11-2015, 10:27 AM   #19
mrk1
Drives: Sterling BRZ Ltd
I took the Mishimoto BRZ kit, used the sandwich plate and core. I made a custom mount and lines to fit my application.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
BRZoomTX (12-11-2015)
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
Fs: custom turbo setup. GT3076R and more glorydays Engine, Exhaust, Bolt-Ons 32 11-11-2014 10:47 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 10:48 AM
FA20CLUB turbo kit advice needed joedaniali Forced Induction 26 02-24-2014 01:25 PM
What to do.. Advice needed fuddbutter AUSTRALIA 44 01-29-2013 07:02 AM
