#15 |
What specifically does the TSB fix/change?
#16 |
On mine they just had to change the weather strip and lifters since it already had the newer switches. I understand that some of the older ones had a different switch installed as well but do not know what was changed in them.
I did not take it in originally for freezing but for the squeal when it was wet. They did both the window/door TSBs and the squeal went away and I had no issues with it freezing. Well, no issues that would not have happened with any other car at any rate since if there is enough ice no window will work right.
| The Following User Says Thank You to Tcoat For This Useful Post: | wheelhaus (11-23-2015) |
#17 |
#18 |
#19 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | KR-S (11-23-2015) |
#20 |
![]() Kickn' it old school
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#21 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
#23 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Sportsguy83 (11-24-2015) |
#24 | |
Drives: 2015 Aozora BRZ
LOL I remember reading that thread before can't believe that worked ! I actually had a similar issue with my 95 Honda prelude the rear tails would constantly stay on, I would have to pull the fuse every night just so it wouldn't drain one day I unhooked the battery and it fixed it, should of tried that first being I am IT |
#26 | |
#27 |
Drives: Pearl White 2014
I'm stuck having this problem except.. the fix isn't working for me .
The drivers side window is stuck DOWN the passenger window won't move using the drivers side switch but will work with the passenger side switch. The drivers side motor clicks when I push the button down but when I hit UP its silent, no response. I've been fighting this for hours and no luck. |
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 03:14 PM |
| Window Visor and Frozen Window TSB | tinma | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 05-19-2015 02:51 AM |
| Window Visors and Frozen Window TSB | tinma | CANADA | 0 | 06-17-2014 03:07 PM |
| Window Scratched by Window Motor / Lifter? | tomkozski | Issues | Warranty | Recalls / TSB | 22 | 05-31-2014 08:25 AM |
| squeaky window due to window rubbing against rubber at the top | tracerit | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 08-10-2013 06:34 AM |
