#15 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
With a good tune, and not raping on the car... 450whp isn't too much of a gamble.
#16 |
OP did you have an 8th gen Civic Si?
| The Following User Says Thank You to cto424 For This Useful Post: | driftking96 (06-30-2016) |
#17 | ||
Drives: '15 FRS
When you see me post a sheet I will either have a time slip or a baseline dyno as context for the vehicle/work/whatever -- hence the baseline in the OP. Random sheets with no context are absolutely worthless. And I do understand what you're saying -- apparently 300 is the new stock fuel system go to figure on some dynos... except on ours 250 and you're done, anything past that you're just a little lucky (we're talking 5-10hp). Even running it a little crunchy for the sake of seeing what this motor of mine will take doesn't get you anything (lol). Quote:
Still have -- about 900hp. |
#18 |
Drives: Velocity Orange 86 GT
Jesus 900hp Civic? Whats that running. I can imaging that it is somewhat scary to drive. I just say American dynos since in Aus mainline or dyno dynamics are the only dynos generally available so they are all fairly similar barring people screwing with them. Yeah and thats been seen here too with the limitations on the stock fueling. About 200kw is possible on a less safe tune but 180-190 is more realistic.
#19 | |
Drives: '15 FRS
lol |
#20 |
Drives: '15 FRS
Had a little fun this weekend:
[ame="https://www.youtube.com/watch?v=ix8v0uxodME"]Turbo FRS Launch Control - YouTube[/ame] Definitely need a better tire :giggle: |
#21 |
Drives: '15 FRS
Looks like we got 500 with a completely maxed out fuel system on E76-E77 fuel! Popped a boost leak during this pull too (blew the CPC hose under the manifold off lol).
The ACT 6 puck doesn't like holding ~400tq, had to ramp the dyno in faster to avoid the clutch letting go (which it did once). ![]() Time for a fuel return and/or even larger port injectors? (currently the 900/1000cc Deatschwerks). The pressure drop from the in tank pump is quite evident at the higher boost levels.
#22 |
Drives: '13 BRZ
Any updated street "closed course" pulls on ~450hp? The other pull video you have is only ~10psi.
Awesome numbers btw! |
#23 |
...Just add nauseum
Drives: 2003 (AP1) S2000
This thread will last as long as the transmission.
Then it will be in the massive pile of "oops I broke the sh*tty transmission and there's no good alternative to it" threads
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | CSG Mike (12-03-2015) |
#24 | |
Drives: '15 FRS
[ame="https://www.youtube.com/watch?v=FCosnrS3Uhw"]Turbo Scion FR-S Boosting in Mexico - YouTube[/ame] Who cares? I don't understand the belly-aching about the transmission. This platform is by far one of the easiest on our plate when it comes to trans repair. The transmission comes in an hour, tops. I can have a new gearset installed the same afternoon, depending on parts availability. |
| The Following 9 Users Say Thank You to VitViper For This Useful Post: | BRZoomTX (11-27-2015), Chrisgalactic (05-13-2016), CSG Mike (12-03-2015), GhostOp86 (05-09-2016), Guff (05-07-2016), Kris86 (12-02-2015), Lonewolf (11-27-2015), nickmerronesucks (04-24-2016), Votlon (05-23-2016) |
#25 |
Drives: '13 BRZ
Not bad at all man, especially on factory tires. Making very good power. Some real tires would be really nice.
Are you running the stock 4.10 rear as well? Your gears seemed a little longer, but its been a while since I've driven mine so I don't recall the MPH limits of each gear. I thought 4th topped at 100 but you hit 108 in 4th I believe. As for the trans, we will have real solutions very soon. Multiple shops are working on t56 swaps right now for 2016 release. Once the 86 gets a real transmission for a bolt-on swap, we are going to be seeing a lot more higher HP builds. |
#26 |
Drives: '15 FRS
Yes it's all stock. Car runs a 7800 limiter and likes to use it. Might just bump it to 8k lol
#27 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I have seen those Mexican roads before! Nice work!
| 2013 White Turbo FR-S (450whp) (Update) (For Sale Again) | Synack | Cars for Sale/Trade | 40 | 02-27-2016 01:55 AM |
| 2006 STi 450whp $25000 | JoeShmoe | Cars for Sale/Trade | 0 | 08-28-2014 05:46 PM |
| 450whp Turbo FRS - TR3 Performance | JPxM0Dz | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 02-19-2014 01:40 PM |
| Auto-Craft Japan Turbo FT86 | BPAuto | Forced Induction | 5 | 05-21-2013 11:57 AM |
| ft86 turbo RWD or AWD? | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-18-2010 05:11 AM |
