Old 08-31-2017, 01:00 AM   #15
Shibby
Drives: 2013 WRB BRZ
Mine has been clicking while on since 45k and I'm at 55k now. Subaru diagnosed it as a failing blower.
Shibby is offline   Reply With Quote
Old 02-23-2018, 05:09 PM   #16
Spectral Entity
Spectral Entity's Avatar
Drives: 16 Scion FR-S Hot Lava, 81 DeLorean
Necroposting to add to the list of people who's blower motors have developed a noise at ~53K miles. Mine sounds like chirping crickets, ironically enough, and began just a few days ago.
Spectral Entity is offline   Reply With Quote
Old 02-23-2018, 07:45 PM   #17
BRZnut
Drives: BRZ DGM Limited
I might as well up date what I did to solve this issue. Mine has made a chirp sound for years when it was cold out. But back in Dec it suddenly starting making all sorts of sounds. What I did was remove the in cabin filter and then spray WD 40 all over the top of the motor (with it running and also with it off). Put the filter back in and let it run for a few minutes. The motor immediately became quiet.
It is now the end of Feb and the blower is still perfectly silent. Cheap and easy fix so far.
The Following User Says Thank You to BRZnut For This Useful Post:
Tcoat (02-23-2018)
Old 02-23-2018, 08:04 PM   #18
Thanks I will give that a shot. Don't think I have owned a Japanese built car yet that the blower didn't start to make noise. Most were a bitch to get to to try to lube and I never thought to go through the cabin filter space. Makes it easy enough to actually do.
Old 02-23-2018, 09:27 PM   #19
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
What the hell would we do without WD-40???
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Tcoat (02-24-2018)
Old 03-18-2018, 09:31 PM   #20
markthegrea
Drives: White 2003 MR2 Spyder
First Post!
My blower motor is going bad to. 2013 FRS with 50,000 miles. Going to try the wd 40 trick.
markthegrea is offline   Reply With Quote
The Following User Says Thank You to markthegrea For This Useful Post:
humfrz (03-18-2018)
Old 03-18-2018, 09:36 PM   #21
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 03-19-2018, 09:46 AM   #22
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
You got me.... I'm not afraid to admit it.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Street Blower? FRed-S Engine, Exhaust, Transmission 33 09-10-2015 04:09 PM
Blower motor (fuse/relay/resistor) problem? fx35s Issues | Warranty | Recalls / TSB 6 01-27-2015 09:06 AM
WTB: Kraftwerks Kit with C30 or C38 Blower jflogerzi Want-To-Buy Requests 0 09-07-2014 01:28 PM
ac blower cfm question shif7i7down Electronics | Audio | NAV | Infotainment 0 05-29-2014 01:54 PM
Blower fan squeal 2point0 Issues | Warranty | Recalls / TSB 4 04-01-2014 07:40 PM
