Old 11-07-2015, 04:36 AM   #15
P3tras
Drives: Subaru BRZ '13 WRB
Originally Posted by Shedd22 View Post
Not sure if it was said since I didn't read all the comments but reset the ECU (unplug battery for a bit). Upon restart it should ask what units you want everything in.
Definitely not, unless you are talking about head-unit
P3tras is offline   Reply With Quote
Old 12-28-2015, 11:00 AM   #16
Ramn
Ramn's Avatar
Drives: 2015 GTI
Originally Posted by cmihaylov View Post
I tried searching for this but couldn't find an answer. If there is a thread on this please excuse me. So my question is, is there a way to change the climate control on the BRZ Limited to read in Celsius instead of Fahrenheit (like on all the other BRZs not sold in the US). Could this be done through TechStream?
Thank you!
Came across this video in case you are still interested:
[ame="https://www.youtube.com/watch?v=6YNoHyFwKyw"]https://www.youtube.com/watch?v=6YNoHyFwKyw[/ame]
Ramn is offline   Reply With Quote
Old 08-26-2018, 09:14 PM   #17
lucas.sidoti
Drives: FT86 - White
In what does all this finished?
Im in this situation too... I bought a digital module to adapt it to my ft86 and its in faranheit ... Any way to change it to celsius?
lucas.sidoti is offline   Reply With Quote
Old 08-27-2018, 01:56 PM   #18
Sasquachulator
Pavement Grey
Sell the car, and buy a Canadian spec model.
Or do a Kijiji trade and see if anyone would trade one straight up US for CAN spec.
Might be easier than have to muck around with the ECU and center stack modification....but probably way more of a hassle lol
Old 08-27-2018, 02:52 PM   #19
Not that easy. Each person would have to pay duty, inspection fees, taxes, and about 10 other charges to swap across the border. Or wait 30 years for the age restrictions on vehicles to come into play.
Old 08-28-2018, 03:29 AM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by azian_advanced View Post
That was so the OP to have his climate control display in Celsius, instead of in Fahrenheit.
I also don't recall seeing it an option in TechStream.
@Ultramaroon able to page through the service manual to find anything?
I'm not available to find it in tech-stream because I own an FR-S and it would most likely not even show that option as available to change the temp control display values. May even be a regional setting hidden somewhere.
Old 08-28-2018, 04:47 AM   #21
Ultramaroon
not playing cards
Ultramaroon's Avatar
Nope. I'm in the same boat as you. We need to plug into one of the special models. Nothing in the manual.
Old 08-28-2018, 12:14 PM   #22
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
Random thought...
Is the HVAC unit firmware flashable through the OBDII and CANBUS? If so, flashing the JDM/Canadian/everywhere else version of the software might do it.
PhyrraM is offline   Reply With Quote
Old 09-06-2018, 01:28 AM   #23
geraldjust
Drives: MR2, Sliver BRZ
Anyone have pictures of the PCB of of the Auto AC? it could be a possibility that the settings for F vs C could be saved in a EEPROM. It would make sense since it has to save your last saved settings (temp and what buttons you had pressed before turning the car off). Or sometimes manufactures to make it as easy as possible on their assembly line when making the PCBs to were its a simple jumper or eeprom setting afterwards.
The temp on the ambient sensor from the cluster it sent as C though canbus so the only thing to worry about is how to switch the controls to C.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 02-20-2019, 10:59 PM   #24
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Does any one figure it out yet? lol
Sorry to bring up a old post.
FR-Sky is offline   Reply With Quote
Old 07-01-2021, 09:33 PM   #25
T_Squadrito
Drives: White 2014 brz
Im digging up this old post too. Sorry if I send out a mass notification. Has anyone figured a good DIY solution to this at all? I stopped using imperial many years ago. Ferenheight is foreign to me now and metric just makes more sense all around. Being on US roads driving everyday, I can still use mph, hopefully thats obvious, but ferenheight is a nogo when I can set my phone, thermostat, and web browser to all assume centigrade first.
T_Squadrito is offline   Reply With Quote
Old 07-02-2021, 02:00 AM   #26
gpvecchi
gpvecchi's Avatar
The AC module is the same for US and EU model, you have to replace the BCM module. This module controls the AC units.
Keep in mind that there are some other difference between modules, i.e. EU doesn't have car alarm.
gpvecchi is offline   Reply With Quote
Old 07-02-2021, 03:30 AM   #27
soundman98
ProCrastinationConsultant
soundman98's Avatar
Other Toyota models have this issue as well. No way to change without a BCM from the appropriate country that has your preference
Anybody Use the Climate Control? carma143 BRZ First-Gen (2012+) — General Topics 32 11-07-2017 08:24 PM
FS: BRZ Dual Climate Control pleong Interior Parts (Incl. Lighting) 0 10-31-2015 05:18 PM
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 06:46 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 02:12 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 09:03 PM
