Old 11-05-2015, 05:21 AM   #15
steve99
Originally Posted by Captainstabalot View Post
Hey guys new to the forum and got my car a week ago. I got it used from a dealership but whoever owned it had already done some mods. Trd exhaust and Springs and K&N filter. I don't feel the torque dip that this car is notorious for so I'm wondering if he did a tune of some sort. How would I find out if there is already a tune on my car?
Their is no easy way to know 100% unless to read the rom from the ecu and compare it to stock.
If you cannot read the rom from ecu then that may also indicate its tuned as some tuning systems ecutek and brzedit disable read.
You will also need a device to read ecu , or access to someone who has one
Some tunes have distinct features some do not.
Old 11-05-2015, 08:02 AM   #16
Originally Posted by Who8myrice View Post
After driving for while, check to see if rpm drops under 700rpm while idle.
Correct me if I am wrong but stock tune does that shit and feels like car is going to stall by itself.
Nope not a good indicator. Mine idles at 600 and is solid as a rock with no tune.
Old 11-05-2015, 08:42 AM   #17
raven1231
Originally Posted by TM View Post
If the previous owner flashed it with an OFT, unless the owner is an idiot, he or she wouldn't flashed it back to stock and unmarried the tablet from the car. Otherwise, s/he'd be stuck with a useless tablet with no resale value.
Which is a very real possibility, especially given the shit I see owners post on Facebook....
The Following 3 Users Say Thank You to raven1231 For This Useful Post:
cdrazic93 (11-05-2015), kch (11-05-2015), Tcoat (11-05-2015)
Old 11-05-2015, 10:32 AM   #18
Captainstabalot
Drives: 2015 Frs
Hey jsimmon7777 I'm in Fairfield. I just tried to see if I have ecutek and nothing happens with the cruise control. 1st gear Rev and let's me go past 6k so pretty solid evidence I don't have a tune. Which makes me happy in the sense I can get more power
Captainstabalot is offline   Reply With Quote
Old 11-05-2015, 12:04 PM   #19
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Even if the torque dip was gone I would still feel it if my other car was an E55 amg.
Old 11-05-2015, 12:10 PM   #20
Captainstabalot
Drives: 2015 Frs
Yea she's kinda slow too
The Following User Says Thank You to Captainstabalot For This Useful Post:
NyC Zn6 (11-05-2015)
Old 11-05-2015, 12:20 PM   #21
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Well, you're not going to gain much from a tune unless you get a header and/or run e85. Also, to save you some searching:
+35 9" wide wheels on stock suspension
+45 with camber and coilovers
yes, RPF1 are still the standard
the car actually understeers at the limit stock until you put down the accelerator
yes, you need an oil cooler to go to the track
yes, you need track brake pads front and rear. Most people go project mu. I am one of the few who like PFC 08.
yes, you need to replace the brake fluid with something higher temp. I like ATE.
No, those coilovers are crap, and that anti-rollbar probably is too
Yes, you want front crash or camber bolts - you'll get about -2 degrees, which is enough for most people
You can adjust the clutch downwards. You can remove the spring. I'll be replacing the cylinder with a smaller one.
SBD makes the cheap turbo. Full Blown makes the drag turbo. PTuning makes the track turbo. Jackson makes the track supercharger.
OFT does pretty much everything that EcuTek does and has a screen for real-time data. It's also not beloved by many tuners who want to lock up their tunes.
The thread about helping the guy find yoga pants for his girlfriend is really just an excuse to post pictures of scantily clad women.
There, now you can leave the forum now. Though you might want to check out the yoga pants thread before you leave.
The Following 3 Users Say Thank You to EAGLE5 For This Useful Post:
Bg8780 (11-05-2015), JB86'd (11-05-2015), Sportsguy83 (11-05-2015)
Old 11-05-2015, 12:27 PM   #22
Captainstabalot
Drives: 2015 Frs
Lol well thanks for the information overload. I don't really plan on tracking this car but wouldn't mind having her ready to do so. This is how she sits now, I think I'll stay around the forum for awhile. T
Old 11-05-2015, 01:25 PM   #23
NyC Zn6
NyC Zn6's Avatar
Old 11-05-2015, 05:36 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Everything you said above is pretty good info except in red.
OFT is not a proper way of tuning if going FI and/or E85. Custom Ecutek maps are required to properly tune an FI 86 and flexfuel for E85.
Old 11-05-2015, 05:37 PM   #25
NyC Zn6
NyC Zn6's Avatar
So I can't buy a turbo kit and get it tuned for 93 pump only with OFT ?
Old 11-05-2015, 05:50 PM   #26
Sportsguy83
Drives: Limited BRZ
You can get it tuned, yes.
I am talking about doing things right, having the proper safeguards in place etc....
With Ecutek you get electronic boost control with CC stalk, you get overboost protection with several parameters, you can input a real wideband into the ECU to be able to properly tune the A/F ratio of the car, different timing/gas maps for different situations, Speed Density for when your MAF is no longer able to provide you a window for tuning because it's maxxed out, etc.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 11-05-2015, 05:50 PM   #27
steve99
You can get turbo/supercharger kits tuned with oft, but its limited to the specific kits offered by either the OFT guys or the Speed By Design guys (SBD).
Other tuners are reluctant to use opensource as their work can be copyed.
you will find that the oft and sdb kits are limited to about 10psi boost as after that you start to need some of the fancy add on features of ecutek software like boost cut, flex fuel, hybrid speed density ect.
However see here ztan has already implemented overboost cut and speed density patches for opensource. Shiv/OFT is now using the overboost cut patch on their OFT 350 turbo kit.
In the not too distant future opensource flex fuel may be done and the gap between opensource and ecutek will be much less.
Their is already a guy in australia "throttle happy tuning" who has flex fuel running without ecutek, its not open source though he uses brzedit and has written his own flex fuel code for 86/brz
although you will still run into the problem of many tuners preferring to use ecutek due locking of tunes and that they dont have to manually patch roms ect, ecutek software does it for them.
http://www.ft86club.com/forums/showthread.php?t=94751
The Following 2 Users Say Thank You to steve99 For This Useful Post:
NyC Zn6 (11-05-2015), Sportsguy83 (11-05-2015)
Old 11-05-2015, 05:52 PM   #28
phrosty
The biggest hinderance to FI with OFT is that when you go FI you generally want a proper dyno tune and those guys won't touch OFT if it doesn't let them lock the tune.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
How can you trust a tune? (tune noob) Benschneider06 Software Tuning 20 05-21-2015 12:03 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 03:49 PM
Dynotronics and their E-Tune/ OTA tune. Ricepuddin User/Vendor/Sponsor Reviews, Feedback, Comments 5 12-24-2012 10:53 AM
