MisterSheep
Old 11-03-2015, 12:11 AM   #15
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Romanov View Post
no Dark grey? this makes me sad
me too. when i first saw them more than a year ago i was thinking of getting them since my wheels poke very slightly. but, alas, no DGM/asphalt. didn't want to spend extra to get them painted. however, i'd like to see the black ones on a grey car to see how much contrast there is.
shiumai is offline   Reply With Quote
Old 02-13-2016, 11:48 PM   #16
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Bump.
Anyone have these installed? Would like to see full side pic by enthusiast.
Packofcrows is offline   Reply With Quote
Old 02-14-2016, 02:11 AM   #17
SPCorBUST
SPCorBUST's Avatar
I would as well. $450ish shipped is pretty steep.
Haven't seen these or the rear side spoiler before. Seems like the latter would still work on a BRZ, just may not look good.
There is a comment about it being more difficult to remove the bumper due to the decreased access of the side marker.
Sent from my SM-G925T using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 02-14-2016, 06:03 AM   #18
ollie
ollie's Avatar
Drives: GT86
Have looked at getting them for some time, you will need to drill holes in your fenders. They don't stick out much at all.
ollie is offline   Reply With Quote
Old 07-06-2019, 03:45 PM   #19
amcluesent
Drives: GT-86
Holy thread resurrection, Batman! Just added TRD arch extensions in 61K body colour to my GT86
amcluesent is offline   Reply With Quote
The Following User Says Thank You to amcluesent For This Useful Post:
Kiske (03-10-2020)
Old 07-06-2019, 08:15 PM   #20
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Hey that’s pretty good! What side skirts are those? They flow pretty well with the fender extensions and the canards. It’s so subtle. Such a nice touch. How easy/hard were the extensions to install?
Will BRZ is offline   Reply With Quote
Old 07-07-2019, 04:26 AM   #21
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Why do you have 2 side skirts? :/
Dr. BRZ is offline   Reply With Quote
Old 07-07-2019, 07:00 AM   #22
amcluesent
Drives: GT-86
> How easy/hard were the extensions to install?<
Lessons learned -
- Fix any deep paint chips on wheel arch showing rust before covering-up
- Use Google Translate app to get the gist of the Japanese instructions
- The top edge of each piece is very sharp from the mould and it's super easy for paint to flake, I'd suggest rolling the edge off with 1500 paper before painting
- Use a frame (see pic) to secure pieces for painting as they need painting all around with body colour (unless you have a car in the colour TRD supply these - red, black, white)
- The 3M tape peel-off layer will get covered in paint, this doesn't matter
- The included J clips are poor and bind up. I had to drill out each one, then run the screw in and out a few times to ensure it tightened OK
- Only expose the smallest amount of double-sided tape on each piece while offering up and securing to J-clips
- Slowly pull the double sided tape from the end with the panel fitting and push piece against body panel to secure as you go
>Why do you have 2 side skirts? :/<
1 louder
Old 11-19-2019, 12:59 AM   #23
MiLo86
Drives: 2016 UM FRS
Does the TRD Fender Flares close the Wheel Gap a bit?
MiLo86 is offline   Reply With Quote
Old 11-19-2019, 02:05 AM   #24
gpvecchi
gpvecchi's Avatar
1 cm
gpvecchi is offline   Reply With Quote
Old 03-10-2020, 12:31 AM   #25
GIM
Drives: Toyota GT86 (white)
Hi - I am about to install a set of the TRD fender extenders. On the rear wheel arch there is a rubbery (painted) strip on the underside edge, did you leave this on or remove it before the installation ? Thanks. Greg
GIM is offline   Reply With Quote
Old 03-10-2020, 03:17 AM   #26
gpvecchi
gpvecchi's Avatar
Leave.
Old 03-10-2020, 03:47 AM   #27
GIM
Thanks - I was concerned about the clip in the attached picture having to stretch over it..
Old 01-22-2021, 08:18 PM   #28
mikko86
Drives: Scion
Bumpin a old thread...I found a set locally for sale but the guy is telling me it just reuses hardware from the fender liner. Shouldn't it come with hardware?
mikko86 is offline   Reply With Quote
can anyone lend me a fender roller and socket extensions/u-joint lp87 Mid-Atlantic 14 06-26-2014 04:58 PM
ForceWerkz: FRS/BRZ Side Skirt Extensions JonMotoring Exterior Parts - The Rest 142 05-23-2014 04:35 PM
No drill side skirt extensions psyclone07 Cosmetic Modification (Interior/Exterior/Lighting) 11 01-13-2014 01:50 PM
