Old 11-25-2015, 01:36 PM   #15
Gringosteve
Drives: UK Spec GT86
Consistent burnt engine/rubber/plastic smell WOT high RPM
Cam plate and cam cover needed resealing on mine. Problem is now solved. So glad of the 5 yr warranty!
Gringosteve is offline   Reply With Quote
The Following User Says Thank You to Gringosteve For This Useful Post:
go_a_way1 (11-25-2015)
Old 11-29-2015, 02:39 AM   #16
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Check the right side sway bar bushing
Digitalanalog is offline   Reply With Quote
The Following User Says Thank You to Digitalanalog For This Useful Post:
Ultramaroon (11-29-2015)
Old 11-29-2015, 02:49 AM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^^this^^^
I don't understand why this isn't a huge thing. Do people not notice a blown-out sway bushing?
Old 11-29-2015, 03:15 AM   #18
Digitalanalog
Mine has seen better days, I'm assuming it from my aftermarket overripe. I wonder if there are aftermarket bushings that can handle the heat better
Old 11-29-2015, 03:35 AM   #19
Ultramaroon
not playing cards
Same with stock. Seems like all but grandma's car would be cooked. Just climbing a long hill at WOT would do it.
Clipdat (11-29-2015)
So that burnt rubber smell - solved (2013 BRZ) exE36M3 Engine, Exhaust, Transmission 9 01-24-2018 01:30 PM
Burnt smell after braking? Tofu-86 BRZ First-Gen (2012+) — General Topics 10 09-23-2015 07:13 PM
Smell of burnt plastic" DaNBrZ BRZ First-Gen (2012+) — General Topics 14 07-15-2013 02:54 PM
Burnt smell coming from rear? gatorbushmen Issues | Warranty | Recalls / TSB 5 04-16-2013 10:21 AM
Burnt Rubber smell Fizzle Issues | Warranty | Recalls / TSB 22 01-06-2013 09:10 PM
