| View Poll Results: Do you have the described AT issues? | |||
| Yes, but I've ignored them |
41 | 34.17% |
| Yes, TSB fixed it |
14 | 11.67% |
| Yes, dealer fix did not help |
12 | 10.00% |
| No everything is fine |
53 | 44.17% |
| Voters: 120. You may not vote on this poll | |||
#15 |
Drives: 2015 Asphalt FR-S
I commented in another thread, but I had the TSB done for the idle hunt issue that seemed to accompany hard shifting for me. So far so good. BUT I want to give this time before I make a conclusion.
#16 | |
Drives: 2013 Scion FRS
I'm going to try a few other dealerships before I call it quits and get rid of this car. |
#17 | |
#18 | ||
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | MechEGR (11-11-2015) |
#19 |
If my VIN is not in the TSB range would the still accept it?
#20 |
Idk, but does not hurt to ask. IF you have idle hunt issues they should try it I would think.
| The Following User Says Thank You to V_86 For This Useful Post: | OpteronO3 (11-10-2015) |
#21 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
wasn't aware of this thread and it seems to describe perfectly the issues i have been having with weird idling especially putting it in park.
TSB will be a nice reason to go to the dealership to have them fill up the coolant as it they didn't last time and now it is low. EDIT: Since this seems to only need adjusting to the TCU and from my quick read won't involve the ECU, has anyone gone in with an OFT tune still on the car or did you flash back to stock before bringing it in?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() Last edited by Tectoniic; 11-13-2015 at 06:46 PM. |
#22 |
Tomorrow will be one week since I had the TSB done. Again I want more time to say anything definitive, but the TSB for idle hunting seems to have fixed my hard shifting issues as well.
#23 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I'm taking mine in this afternoon for the update and i'll update if this seems to help. I should be able to notice as soon as I get home if it is fixed or not.
I was told that my VIN was outside of the recall but I 100% have this issue(early MY15 AT). I'm wishing I had recorded it happening because knowing my luck it will not show up when I bring it to the dealership....
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
| The Following User Says Thank You to Tectoniic For This Useful Post: | KalbiCool88 (04-25-2016) |
#24 |
My understanding is that you should flash back to stock tune. However, if they check they can still tell you ran OFT. I would try a dealer that is more mod friendly.
#25 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I've been to the dealership with tune, headers, and e85 and they are fine with it. I was just wondering if they will be doing any updating to the ECU or purely the TCU as I don't want my OFT to become unmarried. I think i'm just going to leave the tune at this point since it is an hour away. I guess I can let people know if the TCU update will be safe with OFT....fingers crossed
#26 |
The TSB is only to the TCM, not the ECU. Different computers. Manual FRS don't even have the wire harness on the back of the plastic engine cover, so its a separate system.
#27 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
I had the TCU updated per the TSB and now my 1 -> 2 and 2 -> 3 shifts feel a lot smoother. I haven't done any testing yet in sport mode to see if it blips the throttle on downshifts again but that was honestly the least of my worries. It also doesn't have the idle dip anymore when it is put in park after driving.
I think they may have flashed the ECU as well back to the stock tune. This could definitely be placebo effect but the the exhaust note sounds different especially at 4k+ rpm which I know OFT has some changes that actually effect that and the engine is also having very slight knock correction, ~-0.29 for FLKC, at ~1500 RPM with 15-20% throttle.
| The Following User Says Thank You to Tectoniic For This Useful Post: | MechEGR (11-17-2015) |
#28 | |
Not a troll
| AT Transmission Hard Shifting | MechEGR | Issues | Warranty | Recalls / TSB | 95 | 05-21-2017 12:54 PM |
| AT transmission hard shifting issues | calic | Issues | Warranty | Recalls / TSB | 44 | 11-09-2015 07:17 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 01:13 PM |
| Transmission noise when up shifting after hard rev | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 09-03-2013 04:22 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 03:22 PM |
