Old 10-17-2012, 05:19 PM   #15
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Any dyno numbers from someone who kept their car below 4k? I'd be interested in seeing the comparison.
spitz is offline   Reply With Quote
Old 10-17-2012, 06:06 PM   #16
2forme
I followed break in. Put down 175 stock with SRT header back.
Old 10-17-2012, 07:21 PM   #17
Opposed
Drives: 2013 Asphalt FR-S
Mine was a fairly hard break-in. It saw redline quite a few times before 1k miles on it. This was my baseline at about 3500 miles on it pre tune and intake.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 10-17-2012, 07:26 PM   #18
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
hrm so we do make more power after break in..
i want to see some dyno charts from people who followed the instruction from toyota exactly.
Surok is offline   Reply With Quote
Old 10-17-2012, 07:34 PM   #19
2forme
I did. My dynos are posted.
Old 10-17-2012, 07:38 PM   #20
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
you didnt post them in this thread. and you said that it was stock with some header back..that doesnt sound stock.
Old 10-17-2012, 08:05 PM   #21
2forme
No, but obviously if I put down 174, then the header back didn't make 16 whp.
Old 10-17-2012, 08:16 PM   #22
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
yeah...but we dont know that..
Old 10-17-2012, 08:21 PM   #23
2forme
-__-
Old 10-17-2012, 08:34 PM   #24
OrbitalEllipses
Drives: Attitude
Dyno's already posted in a few threads. 172whp (SAE 0.98 on a DynoJet) stock with just an axleback, 1500 miles on the engine, hard break in.
Old 11-10-2012, 02:13 AM   #25
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
We change oils also after the break-in. That's also another factor in power production.
soros151 is offline   Reply With Quote
The Following User Says Thank You to soros151 For This Useful Post:
Surok (11-10-2012)
Old 06-09-2013, 09:32 PM   #26
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I wanted to start another thread to quantify peoples break in methods vs hp reading. Granted there will be discrepancies due to temp, humidity, elevation, and type of dyno but if we can kind of gauge each others readings based on the data provided I think that is doable.
Here is how I broke mine in. I drove the first 800 km fairly easy as per the manual but to get around the no constant rpm while highway driving I would change the gears to lower ones and did that all the time while cruising (One thing though don't be afraid to go to 5k or so rpm while doing this but I stress that a properly warmed up engine is more crucial to engine life and performance, than just making sure you stay below 4k rpm). Once I got to 800km I started to accelerate harder to say 6k, or so than let engine wind down to 2k than wind her back up hard, usually in 3rd or 4th but 3rd is good to keep speed limits within range, second I find is too short. But let her wind down on her own as this will create a stronger vacuum within the cylinder and help 'seat' the rings in the opposite direction, as well as allows the cylinder to clean itself out. I kept incrementing the rpm until redline which finally was reached around 1600km (1000 mi). No problems. Changed the oil at 1800 km and no issues since now at 27000 km.. Even accelerating hard to 4k is good for the engine but again make sure it is nice and warmed up! you will notice as it breaks in, the engine will start providing more engine brake action, especially at higher revs when decelerating. Trust me it works. As I think my dyno sheet proves, seems about 9-10 hp higher than other using the same type of dyno as displayed from another forum.
Anyways, heres the data.
Type of Dyno: Dynojet
Elevation: ~400 ft
Ambient Temp: 71 F
Fuel: 94 Octane
Transmission: MT
Miles on car: 25400
Mods: Stock, new air filter, GC 0w-30, fresh trans oil, and diff.
WHP: 172
WTQ: 143
P.S. not sure how to post pics.....like my dyno sheet.
Gords_zenith is offline   Reply With Quote
Best Break-in Procedure xantonin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 198 02-11-2015 05:40 PM
Are FR-S stereos bus based? speedrye Electronics | Audio | NAV | Infotainment 2 04-30-2012 12:19 AM
Based on the now-known $24,200 US price, the CDN cost Sport-Tech CANADA 34 03-31-2012 11:14 AM
FR-S based Sedan? tripjammer Scion FR-S / Toyota 86 GT86 General Forum 19 03-28-2012 04:06 PM
