| View Poll Results: Engine Failure Options | |||
| Rebuild for NA |
3 | 3.75% |
| Rebuild for Boost |
2 | 2.50% |
| Rebuild for Boost with Forged Internals |
49 | 61.25% |
| 2JZ |
5 | 6.25% |
| LS V8 |
12 | 15.00% |
| Synergy V8 |
2 | 2.50% |
| Sell and Buy Prius |
3 | 3.75% |
| Sell and Buy Other Car |
3 | 3.75% |
| Other |
1 | 1.25% |
| Voters: 80. You may not vote on this poll | |||
#15 | |
Drives: FRS
No sarcasm either, im just learning about cars and looks like you got experience. Sent from my SM-N910T using Tapatalk |
#16 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#17 |
Drives: 2015 Subaru BRZ Series.Blue
I recently blew a headgasket and figured since the motor was being opened to take the time and forge the internals. Dropped to 10:1 CR and will most likely aim at around 16-20psi. The reason why I went 10:1 was mainly because I am moving to the east-coast soon and the location does not have E85 like we do in Socal(Don't want to run meth-inj). 93oct with 18ish psi should be decent enough power for me as it is my daily. I'm running the SBD Kit with supporting mods and plan on upgrading to the 3076 when it is released to shoot for 380-400whp on pump and 450 on E85. As for now, when my motor is done being built I plan on keeping it conservative until I upgrade Turbocharger(or whole kit) and or reinforce the transmission.
#18 |
+1 if my engine blew, forged pistons, rods, and fix what failed (DI seals, valvetrain, crank bearings etc.) that seems to be all there is to do to it right now. As above off the shelf parts, would get the grease under my fingernails DIY.
Right now the two mysteries I see are the oil pressure drop at high rpms and the valvetrain rocker failure, maybe Element is the only ones investigating because they have been unfortunate enough to experience both and they are pushing the limits of the block, idk. But I do know that I doubt my car will see anything more strenous than a CARB legal FI kit of the ~240whp variety. Guess it'd be a rebuild for NA for my vote? |
#19 | |
Senior Misanthrope
https://crawfordperformance.com/prod...100-turbo-kit/ http://www.ft86club.com/forums/showthread.php?t=95265 From what I understand, it basically requires E85 and only gives +100 at the crank (allegedly) at 12psi. All that performance for $4400. |
#20 |
#21 | |
Pretty sad. |
#22 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
All I was saying is for the same money, you could WAY out-build the advertised crawford engine. They're taking advantage of a lack of understanding. As evidenced by the guy who is convinced you need 3K minimum to buy 1200 dollars' worth of parts.
There are many ways to displace.
-Spartarus |
#23 | |
#24 |
Drives: RX-7 / BRZ
I'd go with LJ's built block only because if I'm having a block built Im going to want to have some upgraded top-end parts. Otherwise I'd just do the pistons and rods myself and save a tone of cash.
Also MAPerformance has a built block option too, their turbo kit customers all seem happy with their work.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#25 |
Does the FA20 really need a build block? Isn't that one of the strongest parts of our motors?
#26 |
Senior Misanthrope
| Anyone blown a stock boosted motor yet? | Guildjs | Forced Induction | 514 | 04-28-2020 12:33 PM |
| How reliable is the FA20 motor when boosted? | Zoooom | Forced Induction | 50 | 06-08-2016 07:52 PM |
| Full blown turbo kit, boosted issue. Help please | Xxdragn89xX | Forced Induction | 7 | 09-10-2015 09:37 AM |
| Boosted Twins and motor mounts | FAER | Forced Induction | 42 | 03-07-2014 05:57 PM |
