Old 10-07-2015, 04:38 PM   #15
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Originally Posted by GT86meMR2 View Post
Is the eBay link the correct high pressure fuel pump assembly? And well im not Sure they Always told me "The Fuel pressure regulator" thanks for helping though.
That's the correct part.
That's pretty silly of them, the fuel pressure after the regulator in the tank isn't even monitored. If there was a problem you'd have whack fuel trims as the ECU tried to compensate for fuel pressure being different from expected. The solenoid in the pump is technically a regulator I suppose.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 10-07-2015, 04:43 PM   #16
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Thanks alot will just try and replace the fuel pump assembly Than hope that fixes the problem
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 10-22-2015, 04:17 PM   #17
GT86meMR2
GT86meMR2's Avatar
Problem was the Hpfp got It replaced and evrything is perfectly fine again thanks for helping.
GT86
Old 05-15-2021, 01:23 PM   #18
Mehmet muderris
Drives: Toyota gt86 TRD 2015
I have exactly the same issue since 6 months. I still couldnt find the problem and mu car is doing this thi g once in a while, i already changed my fuel pump but didnt work. Please if anyone has any recommendation tell me what should i do. Thank you!
Mehmet muderris is offline   Reply With Quote
Point in the fuel rail cover? manonastick Engine, Exhaust, Transmission 5 12-11-2016 06:47 PM
High Pressure Fuel Pump Thread crazyfrenchbiker Engine, Exhaust, Transmission 10 09-09-2015 01:32 AM
direct injector injection/rail pressure? WHITE Engine, Exhaust, Transmission 2 07-10-2015 02:06 PM
Crickets possibly fuel pressure target? Tromatic Software Tuning 1 12-16-2014 03:58 PM
frs low fuel rail pressure ? 15,000 miles j0hnnybk01 Issues | Warranty | Recalls / TSB 10 03-04-2014 03:03 PM
