Old 09-10-2015, 10:45 PM   #15
stevo585
Drives: White 2014 BRZ
Originally Posted by dallenj View Post
I recommend it I spent a fraction of what some of the turbo 86 guys spent here and am running faster times. Just be smart about your install. Get the proper safety switches or don't install nitrous unless you want to be a statistic.
Right, all you really need is the rpm window switch, right? I'm in florida I don't think I need a bottle heater. Probably might have to cool it down even.
I bet your trap speeds are slower than turbo guys though as they are liking making more power. You can't be making more than 220whp.
stevo585 is offline   Reply With Quote
Old 09-10-2015, 10:47 PM   #16
dallenj
Drives: Grey FR-S
Does anyone recommend anything else other than an ecutek retune like a stadalone ECM.A local guy in our 86 club recommend a hydra ECM. Didnt know if that would be a smart move
dallenj is offline   Reply With Quote
Old 09-10-2015, 10:49 PM   #17
dallenj
Drives: Grey FR-S
I recommend a wide open throttle switch witch comes with most kits and a fuel pressure safety switch. Thats what I have and have had no issues.
Old 09-10-2015, 10:57 PM   #18
stevo585
EcuTek would be all you need, it can do alot. Might be overkill for a 50 shot though.
The Following User Says Thank You to stevo585 For This Useful Post:
dallenj (09-10-2015)
Old 09-10-2015, 10:59 PM   #19
stevo585
Oh thanks, so you don't have a window switch?
I think thats what killed that one guys motor his clutch slipped, hit the fuel-cut rev limiter and boom.
What you need is a ignition cut rev limiter which Ecutek can do.
Old 09-10-2015, 11:03 PM   #20
dallenj
Drives: Grey FR-S
I do have an rpm window switch as well. Just want to say ot is very difficult to wire it in but be patient
The Following User Says Thank You to dallenj For This Useful Post:
stevo585 (09-10-2015)
Old 09-10-2015, 11:12 PM   #21
stevo585
Does it really cut into the factory harness alot? Meaning removal would be difficult?
Old 09-10-2015, 11:25 PM   #22
dallenj
Drives: Grey FR-S
The only reason why I say it is difficult is reaching the wire. there is only one wire that you actually have to tap into and thats for the rpm signal its just deep in the engine bay. Other than that its just power and ground.
Old 09-10-2015, 11:33 PM   #23
dallenj
Drives: Grey FR-S
I plan on bumping the shot up after I get a tune probably to 75 or 100
Old 09-10-2015, 11:56 PM   #24
stevo585
Do you have access to e85? Id run that if you could.
Old 09-11-2015, 12:57 AM   #25
dallenj
Drives: Grey FR-S
I do have access to it, but there is a tuner I have been in contact with who recommends not to ise nitrous and e85 and I have never ran e85 ay all. If anyone has any more info on it id love here your thoughts on e85 and nitrous.
Old 09-11-2015, 01:50 AM   #26
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I'd suggest you hold off on the final drive until after you've added power. You may find you run out of RPMs too quickly with shorter gears. A built turbo FA20 with nitrous could easily get 500+hp, and many high-hp guys prefer running taller gearing. Just don't forget the E85.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 09-11-2015, 09:23 AM   #27
dallenj
Drives: Grey FR-S
Like I said earlier in this post ill only change the final Drive if I find I need to and I might got strait up nitrous instead of adding a turbo. I plan on 13.5:1 on my engine build to give me more power na and maybe get the HKS stroker kit as well nitrous will be a big boost with that setup. Does anyone one on here have the HKS stroker kit installed would really like to hear what you think about it
Old 09-12-2015, 11:53 AM   #28
dallenj
Drives: Grey FR-S
Just wanting to know if anyone has gotten a 1320 header. Im considering ot for my build but I haven't seen any collector diameters on it. Im looking for a 2.75 inch collector because I heard of rubbing issues with a 3" exhaust.
Nitrous setup Subaru86 Engine, Exhaust, Transmission 6 08-03-2015 01:54 AM
Nitrous build dallenj Forced Induction 34 08-01-2015 03:27 AM
nitrous? ender2664 Forced Induction 48 06-13-2015 10:36 PM
Anyone running with Nitrous? JDMenrique Forced Induction 29 10-21-2012 10:02 PM
nitrous eindio Forced Induction 17 09-22-2012 01:09 AM
