Old 06-22-2012, 08:32 AM   #15
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
The past 10 cars that I've bought all had the same symptom shifting from first to second when cold. There's nothing that can really be done about it.
Grimlock is offline   Reply With Quote
The Following User Says Thank You to Grimlock For This Useful Post:
WillieRX (06-22-2012)
Old 06-22-2012, 09:47 AM   #16
serith
serith's Avatar
Drives: 2009 Scion tC RS 5.0
Both my 06, and now 09 tC do the same thing when it's cold -- have to be careful with 2nd when it's cold.
09 RS 5.0 -- #862 of 2000 -- 5spd
serith is offline   Reply With Quote
Old 06-22-2012, 11:04 AM   #17
DantKR
Drives: Subaru BRZ LT
Start in 2nd
DantKR is offline   Reply With Quote
Old 06-22-2012, 11:09 AM   #18
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
I also have this issue, but it is getting better as I approach 2000 miles. Double clutching and with rev matching can help. However, I've found that just being quick with the 1->2 shift so the revs don't drop in the first place is just as good if not better than trying to be slow and careful.
It was also brought up on the Scion side: http://www.ft86club.com/forums/showthread.php?t=8437
jdrxb9 is offline   Reply With Quote
Old 06-22-2012, 11:22 AM   #19
Jayde
Jayde's Avatar
Glad to hear I'm not the only one noticing this.
Jayde is offline   Reply With Quote
Old 06-22-2012, 11:28 AM   #20
WillieRX
Mountain Road Recon
Drives: '06 Subaru WRX TR
Yep almost every manual car I have had displays similar symptoms when cold (especially in winter.) My WRX trans darn notchy to begin with. Nothing to fret about, double clutch it if your that worried.
WillieRX is offline   Reply With Quote
Old 06-22-2012, 11:40 AM   #21
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I thought it was just me being a rookie with manual. lol. Maybe it is
rcm47 is offline   Reply With Quote
The Following User Says Thank You to rcm47 For This Useful Post:
Sereious (10-20-2015)
Old 06-22-2012, 12:41 PM   #22
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
My 2003 evo did this when the trans was cold. Fluid needs to warm up
Chewie4299 is offline   Reply With Quote
The Following User Says Thank You to Chewie4299 For This Useful Post:
DAN_BRZ (06-05-2013)
Old 06-22-2012, 12:53 PM   #23
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I'm glad I'm not the only one who noticed this, I felt sure this was going to be a warranty fix. I did notice though that even as its warmed up, 2nd, and sometimes 3rd, never gets completely smooth, as in I still feel a slight "clack" vs. and more quiet "slotting-in" as with 3rd and above. I've had this same problem in my old 98 Civic but a transmission oil change fixed it right up and made it all buttery smooth. Hopefully its the same in this case.
Old 06-22-2012, 01:24 PM   #24
TylerD951
Drives: 2003 Accord EX V6 sedan
My 944 and 944 Turbo did that too. It took a lot of force to get from 1st to 2nd when the trans was cold.
TylerD951 is offline   Reply With Quote
Old 06-22-2012, 02:45 PM   #25
davisk6
This is pretty typical for all cars with triple cone synchros in first and second. Subaru tends to use a thinner fluid to help with quick warm up, but its still pretty thick when cold. Just take your time and don't force it.
davisk6 is offline   Reply With Quote
Old 06-22-2012, 04:55 PM   #26
Turbowned
Turbowned's Avatar
Ease it in, like a gentleman!
Old 06-23-2012, 04:14 AM   #27
Gaen
Drives: the speed limit
http://www.ft86club.com/forums/showp...&postcount=283
Originally Posted by whiteout fr-s View Post
alright guys,
As I am the first person to actually let Toyobaru technicians fully diagnose my car, Subaru and Toyota sent 2 technicians each from Japan too actually diagnose my engine and these issues we are experiencing.
So, to begin, the issues are NOT normal and need to be fixed. The technicians fixed some valves, readjusted cam angles etc.. but I will get the full repair specs Monday. They are also tracking my car tomorrow and Sunday to get full engine read outs for future FR-S owners. So as of Monday any of you experiencing this problem will have a fix, and a quick one at that.
I have not had my car for a month now because of this but I can tell you that as long as I know that future owners will not experience these problems it was well worth it. Good luck to everyone who has had this issue and if you are still experiencing this please take your cars to the dealership over the next month and your problems should be addressed a lot sooner than mine!
Gaen is offline   Reply With Quote
Old 06-24-2012, 12:51 AM   #28
inimitable
inimitable's Avatar
Drives: SSM 6-MT limited
I was going to make a post about this myself. I have noticed the same thing. It's hard to get out of first, and into second, almost all of the time. Sometimes, it may be easier when I try to change gears while at higher rpms, and while accelerating.
The other option is to double-clutch it. If you try to pull out of first gear and it doesn't want to budge so smoothly (and you don't want to yank it), try easing off the gas (so don't get all jerky) and releasing the clutch completely. Then re-engage the clutch (and gas, if necessary) and, I've found, a lot of times it will work smoothly.
I thought/hoped this problem was exclusive to Hondas I was hoping to have something nice and smooth. The transmission seems no better than my RSX type-s with 100K miles.
inimitable is offline   Reply With Quote
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 08:15 PM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 01:56 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
How's the shifting of MT compared to other cars Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 25 06-07-2012 11:20 AM
